Surf rear diff bearings and seals
KIWI_TERRANO
Post by KIWI_TERRANO »
I just took a drive to the shop and came out to find a big pool of oil under each wheel on the rear diff.
Once i got home I pulled off the drums and the oil is leaking ouT the outer seals.
Ive heard they are hard to replace,
Any advice where to buy parts?????
And how to replace them,
Anyone in chch keen to help me out??
Im happy to provide beer or pay! :D
kbushnz
Re: Surf rear diff bearings and seals
Post by kbushnz »
Before you do seals check the diff breather is not blocked.
If blocked the oil/air will heat up and expand and if the breather is blocked it will push past the seals.
From memory you have to pull the axles and remove the bearings to change those seals.
May as well get bearing kits.
Calvin
KIWI_TERRANO
My breather hole is bit small going to fit a bigger one, was going to get bearings as one as dodgyish,
Heard many ways to get them apart, if anyone can help me out it wouldbe great!
tallsam66
Post by tallsam66 »
This will give you an idea of how to do it.
Personally id get a mechanic to replace the bearing .....id just remove them & reinstall the axles myself.
http://toyotasurf.asn.au/techsite/wheelbearings.htm
KIWI_TERRANO
Anyone got acess to a press then? :)
LOLYF
Post by LOLYF »
where abouts are you?
I have a press and a jig set up for hilux/surf wheel bearings, but may not be much help if your in the south island :lol:
KIWI_TERRANO
Yep bummer it in CHristchurch.
Thanks tho :)
Return to “Toyota”
