wanted, guard extensions
Timmy511
Post by Timmy511 »
as per title, going to br fitted to a 70 series, what have you got or do you know where i can buy some from? cheers, tim.
bda4130
Re: wanted, guard extensions
Post by bda4130 »
Go to bunnings, they sell this plastic stuff for running round the edge of your garden, works primo and is only about 25 bucks for about 5 meters of it, found out about it on this site, running it on my truck and it's proven to be pretty bullet proof.
getsum
Post by getsum »
do you get wofs with that fitted??
cheaper than what some guys are wanting for stock flares for a surf :x
bda4130
Post by bda4130 »
Yup, no probs for wof, just recently got a cert, and had no issues, my wof guy says they're fine so long as they cover the tires and dont have sharp edges that could cut the old people you might mow down.
UBZ
Post by UBZ »
problem with garden edging is when you get up against a rut or bank it won't flex. it just pushs in untill the mounts rip out or the panel deforms.
rubber is a much better option IMHO
kbushnz
Post by kbushnz »
You can get flexi rubber flares from NZ bus and Truck,
Buy it by the meter....
Buy only what you need...
Don't need to buy a box just to replace one if it gets damaged.
Always in stock....
Calvin
Swamped
Post by Swamped »
I use conveyor belt. Its fibre reinforced and can take a bit of a beating while bending out of the way of stuff that can damage more rigid guards/flares.
Timmy511
Post by Timmy511 »
ive got some lino flooring off cuts, flexy, tough and cheap, what do you reckon?
T-Boon
Post by T-Boon »
To Boon or not to Boon.
kaney
Post by kaney »
I have 5m meters of of the wide actual guard rubber that i got for the jeep that never got put on. you can have it for what I paid if you want. (cost)
toymota thats stock standard.
Rural53
Post by Rural53 »
T-Boon wrote:I run this, works pretty well !
http://www.pararubber.co.nz/product.php?id_product=423
Pararubber sell a flexiflare type rubber extrusion as well.
4WDbits
Post by 4WDbits »
Pararubber have a range of widths and thickness. Buy it by the meter, good and flexible.
Big Will
Post by Big Will »
what do they call it?
I cant seem to find it on the website
5L+GT35@21psi= 223RWHP
5L+GT35@30+psi= 287RWHP....
Great tow Vehicle!
