This is transported for another build thread hosted elsewhere....
right-e-o......
I thought i may as well itemise what i do with thing somewhere, so i can look back one day and go "WTF was i thinking!!!"
So, purchased 10 July. 4.5 butchered lift, adjustable everythings, 33 Scorpions, 15x8 rims and ARB fron winch bar, lockright in front (debating wether to leave that in there)
So far.........
ditched the factory stereo, and replaced it with a jbhi-fi el cheapo, but one with the aux insert so the bride can get funky with the new ipod.
Replaced battery and terminals
Ordered new 3.5 inch front springs to replace the current set up of stock springs with ACOS..... enroute now from Ironrock offroad.
Popped the 249 fulltime 4x4 transfer case out this arvo, nice and easy....measured both input shafts.... 22mm a piece (some are 19mm, some are 1.5 inch)... swapped the speedo sensors over, (one had 3 flat prongs, the other had 3 round prongs) and bolted it all back in. Took 3 hours from go to woah.
The bezel wont need to be changed at the selector, (though i might anyway, 'cause Im like that) as the range is indicated on the centre dash panel, blank for 2wd, then 4-full time, 4-part time (i think it was that order??), neutral is blank, and then up comes "lo".
The gears from 2wd through select sweet, without having to adjust the linkage, but coming out of lo up to 2wd is a little different. After a little trial and error, i figured i need to back up a few feet before the 4wd pops out and 2wd is off again. I wondered if it were the front locker binding, but cant see how. It might just need a little tickle on the linkage.
And oh what a difference driving it in 2wd is.... a pleasure even.
Old shock boots come in handy sometimes
I'm picking it never saw many kms before being wrecked
This weekend...... off with the plastic rear bar, and hoping to begin banging up a rear bar with swing out tyre carrier.... these stash the spare in the rear, and a 33 wont fit. its likely to be a combination of a tomkin carrier ( http://ep.yimg.com/ca/I/collinsbros_2114_8165137 ) a protofab steel rear bar for the centre to take the carrier ( ( http://www.protofab4x4.com/products.php?ID=00&ID2=63 ) and the protofab tube bar for the wrap around ( http://www.protofab4x4.com/products.php?ID=00&ID2=24 ) But we'll see how that goes. I really dont like how the yanks rely on shackles for their recoveries. Some of their bars arent actually held to the vehicle with f-all... in one case a bar I bought was to be held to a 2mm bit of panel steel with 8 x grade5 10mm bolts..... negro, puhlease!
After that..... well who knows....
