2lte - Changing from electric to mechanical diesel pump
Filthy4x4
Post by Filthy4x4 »
Hey guys
Just wondering if theres an easy way to change my 2lte electrical pump over with my 2lt one from the old motor.
I have found this http://www.toyotadiesel.com/forums/showthread.php?p=44829#post44829
But it looks like a bit of a mission :roll:
I need to get it done asap (in the next week or so) I spent all my money buying the motor so just looking for the cheapest/fastest way to do this 8)
Caleb
027 MUD GEAR - (027 683 4327)
Check our facebook:
Big Will
Re: 2lte - Changing from electric to mechanical diesel pump
Post by Big Will »
pity you are in auckland..
It is a straight forward job but it does have a couple tricky bits which do need a bit of an experts eye cast over them,..
5L+GT35@21psi= 223RWHP
5L+GT35@30+psi= 287RWHP....
Great tow Vehicle!
Filthy4x4
Post by Filthy4x4 »
Big Will wrote:pity you are in auckland..
Your telling me I hate this place :lol:
What sort of tricky bits are there? Is that guide the only way to do it?
Check our facebook:
tweake
Post by tweake »
yours should be fairly straight forward as your surf is setup for the mechanical pump. its probably just a case of unbolt pumps and swap them over and all the intake butterfly setup. possibly the injection pipes if required. only thing i would have to check is if the 2lte has the timing marks.
Filthy4x4
Post by Filthy4x4 »
To unbolt the pumps I guess its a cambelt off job still? Theres no easy way around that?
Are you meaning the cam timing marks or the pump timing marks?
Check our facebook:
tweake
Post by tweake »
still needs to remove cam belt.
just not sure if the 2lte has pump timing marks. sorry i forgot to drop into the workshop and check.
Filthy4x4
Post by Filthy4x4 »
No worries dude. Its has all been done now :mrgreen: HUGE thanks to Sibainmud for the help 8) would have been a nightmare without him :roll:
Check our facebook:
tweake
Post by tweake »
what did you end up doing in the end?
sibainmud
Post by sibainmud »
Changed pump over to mechanical, changed cam belt, timed all and adjusted fuel pump timing with a DTI gauage. Just got to change clutch and flywheel, pulleys and belts and It'll be good to go.
Welcome Caleb 8)
tweake
Post by tweake »
sweet as :D
