Does the windscreen fit with the front hoop that straight??
I reckon a little kick back in the hoop, starting at the top of the fire wall following the rake of the windscreen would look cool??
Either way, its looking Wicked
Sadam_Husain wrote:had you thought about just lifting the front guards up for tyre clearance (an easy little mod to do ) instead of the frankeshackle that will become a frankenarchilliesheel that will get your truck hooked up and stuck every 10 metres?![]()
DieselBoy wrote:Looks like the business!!!!!!
Either way, its looking Wicked![]()
skid wrote:should of done it once, done it right Willie
as discussed, you should of built the full internal cage with screen/top/doors on and had removable rear stays/braces, then you can easily return it to the desired workshop hack after the event![]()
I will be over today and will be buying a box of tissues on the way![]()
you ruining a good truck
Smurf wrote:just thought I'd throw this in here to console Skid a bit.
http://www.trademe.co.nz/Browse/Listing.aspx?id=377280570
niblik wrote:how tall is chris cos its lookin taller than mine...?!?
