my son found this place on the net a cool idea for those running rear drums
http://www.chtopping.com/CustomRod4/
drilled drums
drilled drums
Re: drilled drums
would it be legal here !!! temping as drums front and rear
Re: drilled drums
well would you tell the powers that be
Re: drilled drums
its when things go oops
that it matters
Re: drilled drums
should work just like drilling rotors. trades surface area for scuffing the pads. not sure of it would weaken the drums, especially as drums are so prone to cracking tho rear brakes do so little braking it probably won't matter.
