Hilux Dual Transfer Case Adapters F/S
Moderator: Vendors
Hi,
I have got some trailgear dual transfer case parts as below.
Costs are plus freight from Hamilton.
Trail-Creeper™ Dual Transfer Case Adapter 21 Spline $550
Trail-Creeper™ Dual Transfer Case Adapter 23 Spline $550
23 Spline Input Gear $250
Creepy™ Twin T-Case Shifter Forward Shift $225
Creepy™ Twin T-Case Shifter Top Shift $225
PM me if interested
Thank You
Tim
PM me if interested
Thank You
Tim
Re: Hilux Dual Transfer Case Adapters F/S
Bump
Tim
Tim
Bump
See first post
Tim
See first post
Tim
Hi,
Bump
See first post, PM if interested.
Tim
Bump
Tim
so what exactly do these fit on ?
Do you have some more info ?
To Boon or not to Boon.
Hi,
They fit on Toyota Hilux gear-driven transfer case, enables you to put 2 together to get really low gearing.
See http://www.trail-gear.com/dual-adapter
Tim
Tim
If you are really into technical 4wding (ie not just bush bashing or mud plugging) this is one of the best mods you will ever make to a lux
Along with lockers
Tim
Tim
ah, makes sence. can you chose to only use one transfer? or is it both or 4wd high ?
[EDIT] ah, so you get 2 transfer leavers, e.g you have to cut a hole in your floor and sus out a gearbox boot etc ?
Hi,
Bump
Tim
Bump
Tim
Hi,
Bump
Tim
Bump
Tim
Hi,
Bump
Tim
Bump
Tim
Hi,
Bump
Tim
Bump
Tim
Hi,
Bump
Tim
Bump
Tim
Hi,
Bump
Tim
Bump
Tim
- flyingbrick
any for nissan?
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump.
See first post
PM me if interested
Tim
See first post
PM me if interested
Tim
Bump,
See first post.
PM me if interested
Tim
See first post.
PM me if interested
Tim
Bump,
See first post.
PM me if interested
Tim
See first post.
PM me if interested
Tim
Bump,
See first post. Prices dropped a little bit
PM me if interested
Tim
PM me if interested
Tim
Bump,
PM me if interested
Tim
PM me if interested
Tim
Bump,
PM me if interested
Tim
PM me if interested
Tim
Bump,
See first post.
PM me if interested
Tim
See first post.
PM me if interested
Tim
