What suspension lift is best for my 89 vitara?
brakes-shocks-lockers-etc
Roxxty
Stropper
Post by Roxxty »
Hey Guys
I brought an 89 suzuki vitara and just wondering what suspension lift is better? the 2 or 3 intch calmini kit? Im going to get it through 4wd accessories in chch.Would the 3intch kit be algood on 30s or 31 tires,
CHeers :)
lincooln
Re: What suspension lift is best for my 89 vitara?
Post by lincooln »
hi and Welcome.
I would say a 2 inch would be fine for 30"s and the three inch for the 31"s. also be careful with calmini as there struts are prone to failure. Have a looksee at this topic here: http://www.offroadexpress.co.nz/Forums/ ... 23&t=25955
(Bear in mind whatever I say is based on other peoples experience, so do not swear by my word)
Lubrication Specialist
Lubrication Engineers
Roxxty
Stropper
Post by Roxxty »
Thanks Bud :) I was going to go for the 3intch lift..But just wanted to get other oppinions lol (excuse the speling)
Ill prob get them profesinally installed rather than myself too.
its my 2nd car,brought it for 4wd only so woulnt get used everyday.
thanks for ur imput
zukmeista
Post by zukmeista »
Apparently the calmini kit isn't that great. Struts and rear shocks are crap and the springs don't give a soft ride. I have read this off another site, but it has been said by a few people now. I reckon you should look at EFS. They have quite a good name in N.Z. :D
Pico42
Post by Pico42 »
I have also heard mixed reviews of the calmini struts - one of the local club members took his new 3" kit on on trip and the struts fell apart.
There is the relatively simple option spelt out in the Cheap Vitara Lift thread in the Suzuki board here. I have recently taken that and upped it to 3", along with 2 1/2" body lift for 31" tyres. And some other changes.
There is a set of OME springs on trade me at the moment, $400 from memory. A matching set of new OME shocks is about $800 or so. Plus a few other parts ( diff spacer) - how does that compare to the calmini 2" set up?
I would also encourage having a go at doing it yourself, unless you are a complete mechanical retard or a complete lack of tools. It helps you understand what you are doing with the vehicle.
Roxxty
Stropper
Post by Roxxty »
Yeah Im getting some shocks of trademe,and my mate has sum springs lined up for me,Gona be way cheaper than the calmini kit option
Swamped
Post by Swamped »
Just springs and shocks will balls up the camber and cv angle in the front. You will want some camber adjust bolts and check to see how much worse the cv angle is after fitting, could consider changing front diff height later down the track.
