Whats the chances of organising a Chch Beginners day?
Are you coming along to the training day?
Yes I am a definte.
18
78%
Maybe, maybe not.
5
22%
Total votes: 23
JTop
Post by JTop »
Standard Toyota L/C hooks straighten @ 4.6 tonnes, About the same as a Bushranger hook.
Hilux hooks however, by design, push the rope further away from the mounting plane of the bolts, causing the rear bolt to stretch and snap , then shearing the front bolt, 8.8 bolts failing @ 4.5 tonnes.
Bighorn hooks do the same thing, std 10mm bolts failing arround 5 tonnes,
Drilled out to 12 mm, 8.8 bolts still fail but 10.9s hold till the hook breaks @ 8.18 tonnes.
All of these tests were straight pulls on a test rig not snatchs
J Top
worzel
Post by worzel »
if not moving house will be there
kiwipete
Post by kiwipete »
This trip is soundin like a Sth Island "ORE" get together , meet the family trip.
I like it. :D
Ph 0212078472
Muscles
Post by Muscles »
Hi there shane, are you still doing your family trip today?? :)
DaveM
Post by DaveM »
hiriklux wrote: shit $ buy now price they sound bloody expensive
glad i own a standard toyota :lol: :lol: :lol: :lol: :lol:
cheers rik
It is a tad expensive, but if they go on Safari's they have to be built strong to spend all day recovering Toyota's :lol:
BrentC
Post by BrentC »
DaveM wrote:I thought that rated hooks were used as they were designed to bend open when overloaded, rather than having a higher rating than the straps?
Thought that was why a lot of clubs won't allow pintle hooks as recovery points.
Either way, you can buy these for the rear of a safari:
http://www.trademe.co.nz/Trade-Me-Motor ... 594552.htm
Muzzaduck does good work - well thought out and engineered :D
Shane
Post by Shane »
Muscles wrote:Hi there shane, are you still doing your family trip today?? :)
I didnt check on here this morning sorry,yes it was a great day out.
Shane
SupraLux
Complete Bastard
Post by SupraLux »
JTop wrote:Standard Toyota L/C hooks straighten @ 4.6 tonnes, About the same as a Bushranger hook.
J Top
Thats useful tech... might have to combine all these figures into a tech doc in the library section...
Does anyone have access to the video clip where they tested recovery forces and found that even violent snatches were only peaking at around 3.5 tonnes? Its all from a very hazy memory of seeing it somewhere...
Anyway, Wednesday night at the shed I'll be fitting a tow hook to a Surf... anyone else want to come down... make it a pizza, beer and towhook evening? We can do a pre-inspection of your setup... make some recommendations, maybe fit a couple of hooks...
Steve
Elmo
Post by Elmo »
I could be tempted, wheres "the shed"?
SupraLux
Complete Bastard
Post by SupraLux »
or here if you have Google Earth:
"The Shed - 4WD Stuff" lat=-43.4270866298, lon=172.692202545
Steve
kiwipete
Post by kiwipete »
I might see if I can make it out Steve. Did you have a time in mind?
Ph 0212078472
worzel
Post by worzel »
sorry chaps cant make it moving house
Kev
Elmo
Post by Elmo »
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Toyota/Other/auction-67594552.htm
Is something like this classed at rated? Not so much the hook part, but the plate section its welded too.
Reason I ask is because I need something like this for the back, but Im sure not going to pay that price for one. Id make it myself.
In making one, as thats all I assume that person is doing. Do you need to get it rated? Or what goes on there? AM I just allowed to make one myself, or do I need to get an engineer to weld it and cert it?
albundy
Rolly Polly
Post by albundy »
Hook looks fine I would queston the suitabilty of what is connecting it to the chassis though. I saw a very similar design last year, on a well equipped rugger on our club trip to big barn bay down in sth westland. It tore, yes tore off at the mounting bolts through the plate connecting it to the chassis. This equated to a missile connected to a rope flying through the air, no damage luckily, except to the tree it hit. Go and see Steve he will set ya right. 8)
Al
Elmo
Post by Elmo »
Yeah, planning to do so.
I dont like the look of pulling stright onto 4 bolts. Even though tensile stretch is probably stronger than shear. And yes, you are quite right in that the ends of the cross bar it is secured to, dont look all that strong.
Ken
Daz
Post by Daz »
I can probably make it steve, could test out the retrieve speed on the winch if ya like??
Winch works well, pulled out a well stuck range rover down the mak on Saturday with it.
Kiwipete I could give you those Cd's if you go.
JTop
Post by JTop »
4x M10 8.8 bolts failed at 11 tonne on a straight pull
However on a 70 degree angle they failed at 6.16 tonnes
Patrols only have 10mm mounting bolts, most vehicles have 12mm at that point.
This did not test the strength of the factory captive nuts.
4 x M12 8.8 bolts stalled the test rig @ 20 tonnes on a straight pull and failed just under 10 tonne on a 70 degree angle
J Top
DaveM
Post by DaveM »
Have seen this area on a Safari deform from a hard recovery, which is why I just had my hook mounted on the rear bar:
http://www.equip4.co.nz/rear%20bumper.htm
Elmo
Post by Elmo »
Thats a pretty heavy duty tow coupling. Looks like something I wanted, but never got. I got a tow bar put on my truck, and asked for a heavy duty one. Got nothing like that though.
I guess Steve will put me in my place on Wed night, and tell me what I need to do. hahahah
SupraLux
Complete Bastard
Post by SupraLux »
Yeah, I'm not a big fan of the 4-bolt recovery points on the rear of a truck, and have always been stunned that my little MU has M12 bolts and a big-arse ugly mutha GQ poo-troll has M10's... crazy!
I prefer to mount the hooks inline with the chassis rails, and for safety reasons, the passenger side rail in case something comes back at ya (that way it hits the passenger rather than you :P Eh Rik, my trusty co-pilot :D)
However, if you've got a good solid rear crossmember, with good condition M12 captive nuts then the bracket is (well, should be) safe to use - or you can drill through, sleeve and plate the crossmember to add strength and allow for new M12's.
The only difference between that rear bracket from TradeMe and the one I make is that I use folded 6mm plate with gussets on either end double-welded... theres not a lot of room between the bolts for weld fillets.
Sometimes its a matter of comprimise, maybe centre mounting the hook when you want it on the rail, or running the hook upside down when you'd rather have it the other way up... which is ok, as long as the finished product is effective, safe and strong.
Anyway, 5:30/6pm at the shed seems like a good time... all welcome... bring pizza, bring a couple of beers (ie, 1 or 2... no drink driving), bring hooks, bring your truck... if it rains, it will have to be postponed as theres not a lot of inside room.
Steve
kiwipete
Post by kiwipete »
Daz wrote:Kiwipete I could give you those Cd's if you go.
Sounds like a plan, cheers.
Ph 0212078472
wjw
Post by wjw »
SupraLux wrote:Anyway, 5:30/6pm at the shed seems like a good time... all welcome... bring pizza, bring a couple of beers (ie, 1 or 2... no drink driving), bring hooks, bring your truck... if it rains, it will have to be postponed as theres not a lot of inside room.
Whens this? could SAS the Lude... ;)
Who knew Prados could fly?
hiriklux
Post by hiriklux »
tommorrow , wednesday , mid week,
all the above :lol: :lol: :lol: :lol:
cheers "elite" rik
wjw
Post by wjw »
hiriklux wrote:tommorrow , wednesday , mid week,
cheers "elite" rik
bugger, in Punakaiki :(
SupraLux
Complete Bastard
Post by SupraLux »
cheers "elite" rik
Bring me back a nice flat rock :lol:
Yep, tonight... 5:30/6ish... someone bring pizza or there will be trouble :lol:
Steve
Elmo
Post by Elmo »
I'll be bringing one, but that will disappear between me and the missus, are we ment to bring enough to share?? might be able to spare a couple of bits, but you'll have to fight the red head!! :-D
kiwipete
Post by kiwipete »
Was a good night folks. Nice to put some faces to names, what's ur name again, I forgot. :oops:
Pitty Steve was latish tho. :shock:
Ph 0212078472
MATT4U
Post by MATT4U »
how latish was he, hehe
Elmo
Post by Elmo »
Let say I was about to leave at 7, and he hadnt turned up yet!
He did show, just after though.
H2OLOVA
Post by H2OLOVA »
Good to see i wasn't the only one who turned up late :? Was a good excuse to talk crap though.
BTW i think Rik should convert his truck to LPG, There was enough gas there last night to do a SI trip :shock: :?
Return to “Planning a trip?”
