hi, ive just fitted a new winch to my truck, spent ages doing so fabricating etc, finally get it done, wire it up and it only spools out! so i swapped the wiring round on the solenoids and got it to spool in but now it wont spool out, both solenoids click but im noit sure those china men have wired it up correctly, has anyone got a diagran or a detaild picture of the solenoid box on theyre cheap china winch? mines a ridge ryder from super cheap auto but im sure theyre all the same.
any help much apreciated, cheers.
winch solenoids
Re: winch solenoids
don't know if the first two pics help......
http://www.offroadexpress.co.nz/Forums/ ... 94&start=0
if not the guys who helped me sort mine should be able to help
v8 tj...luvs the gas......
Re: winch solenoids
cheers fella, unfortunatly thats a seal contactor, mines two silver solenoids.
pissed about with it for ages tonight, cant figurew it out, most diagrams (warn winches mainly) show 4 solenoids. with mine having two its hard to find a wiring diagram.
Re: winch solenoids
Chuck a photo up. Not much to them.
Re: winch solenoids
i know its a slow reply but i just found this on another website
Re: winch solenoids
is this a tiger 11 winch?? i have the same problem when i fitted mine. Cant remember the colors, but there is a small wire (Black i think) that attaches to a large contact on the motor. when i looked closely at it it had a clear varnish like substance covering it. i cleaned it off, reconnected it and haven't had a problem since.
Tony.
Re: winch solenoids
It isn't a Tigerz11 Winch or Solenoid, we have never used solenoids like that!!
Brett
Brett
Re: winch solenoids
Mudhog wrote:It isn't a Tigerz11 Winch or Solenoid, we have never used solenoids like that!!
Brett
X2
Biff that solinoid pack and use a intergated/fully sealed one
Re: winch solenoids
Did you get this sorted?
Depending on what part of the country you are in, you could borrow one of our TG Thompson Solenoids to try and check that the winch will work.
Give me a call or PM me.
Brett
021 724 309
Brett
021 724 309
