2002 d/c hilux SAS
2002 d/c hilux SAS
Just wondering if any one has done a SAS on a 2002 shape hilux ute?
Is it any diff from doing any other hilux being newer?
Cheers for info
Cheers for info
Re: 2002 d/c hilux SAS
I think people sas fairly modern trucks in the states, try a google search, I think they're called a Toyota tundra? Might be similar to the hilux.
- KIWI_TERRANO
There one floating around chch saw it today while i was in town, Its a silver extra cab with a bob tailed deck looks smart.
Try ringing Johns road warrent of fitness assuming thats there name seen it there a bit or they could point u in right direction.
Wont be to hard to do ozs do it , think it would be same as my surf.
- KIWI_TERRANO
Infact heres a website http://www.scribd.com/doc/25507362/Johns-Road-Garage
Has contact details there.
Just ask if you can find out who owns the silver extra cab solid axle hilux that parts out front, I would be keen on detail to
it is leaf sprung btw
Hi, the main difference compared to the older luxs is that i think like the 185 surf's and 95 series Prados they use a T/case with a front output on the Left instead of the Right so there inst a Toyota diff casing with a left side pumpkin. I think most will flip a front 80 series housing but not 100% sure on that.
And they are quiet a bit wider than any older Hilux based trucks so the width of the 80 series casing is the better option.
- KIWI_TERRANO
the 02 luxs (shape befroe sheep shager) are same width diffs as the ifs surfs etc, the sheep shagers you have to use 80series and chop section diff
skux wrote:Sorry to clear it up, Its this model here:
http://www.trademe.co.nz/motors/cars/to ... 550194.htm
Oh right that model, i just thought it was the new shape when clearly you stated it was 02 so i should read things more clearly
I think they have the front output on the right side like all the older Lux's so the best diff would prob one from a 71/78 series Prado and they are High Pinion and have slightly stronger cv's aswell.
But if keeping leaves and using the Prado housing you would have a bit of grinding and fabricating to do so it would be easier and also give you a much nicer ride if you used the entire Prado coil set-up with radius arms etc then you could easily find a rear diff from a 130 surf and throw that under the rear to have a fully coiled truck.
If staying leaves it would be a easier option to use a older model front housing with the leaf perches as per factory.
other guys that know more about this stuff might chime in soon and give you more in depth ideas and solutions
- KIWI_TERRANO
As I said before mate
KIWI_TERRANO wrote:There one floating around chch saw it today while i was in town, Its a silver extra cab with a bob tailed deck looks smart.
this on is a old chas with new cab
scott gibson
- KIWI_TERRANO
radar21 wrote:KIWI_TERRANO wrote:There one floating around chch saw it today while i was in town, Its a silver extra cab with a bob tailed deck looks smart.
Are you sure the 4 times Ive seen it and it looked like it had just be done and didnt look like a factory chassie??
yeh pos its a beamed ln130 chas was there when it got cert
scott gibson
- KIWI_TERRANO
radar21 wrote:yeh pos its a beamed ln130 chas was there when it got cert
oh shit looks good, leaf front rear and all the jazz
