Pop Quiz, why would you do this?
wjw
Post by wjw »
Who knew Prados could fly?
De-Ranged
Re: Pop Quiz, why would you do this?
Post by De-Ranged »
so it won't fully engage making it the weak link???
Cheers Reece
mikee
Post by mikee »
Do you mean like a fuse Reece.
Lynx
Post by Lynx »
De-Ranged wrote:so it won't fully engage making it the weak link???
Cheers Reece
Thats about the only possible answer, hahah.
Or its to weld up a crack hahahahahhahah.
Cheers Daniel
nstacey
Post by nstacey »
Found this pic on the net (easier than taking one)
Surely it'll still work ok in one of those large grooves indicated where the weld is?
85 Hilux single cab
02 Grand Vitara
mudlva
Post by mudlva »
nstacey wrote:Found this pic on the net (easier than taking one)
ah yes thats because the tosser didnt know how to assemble properly and thats the reason why people should have a NZFWDA license before they would be allowed to buy a welder :lol: that will stop all of this unwanted energy being consumed when the idiot should be inside doing the dishes not playing with 4X4 wheels and associated bits and peices :wink:
rokhound
Post by rokhound »
I reckon you will find that the tag on the spring has broken and that is what is being welded back on. Pretty bogan, but probably did the job as well.
De-Ranged
Post by De-Ranged »
rokhound wrote:I reckon you will find that the tag on the spring has broken and that is what is being welded back on. Pretty bogan, but probably did the job as well.
that makes more sense the tag fits that grove
Cheers Reece
mudlva
Post by mudlva »
it does not look like the weld makes it to the spring tho
more of the weird and mysterious that peolpe do in the privacy of their own sheds
wjw
Post by wjw »
The weld doesn't touch the spring and from I can see the tab is still there.
My guess is that this guy has experienced taking one of these off in the bush and having it come apart and dropping bits in the mud :-)
I have an additional clue to the mindset of the person. Both hubs were in a tied bread bag, inside a tied shopping bag, smothered in oil
Return to “Tool Shed”
