removed the cat from exhaust sounds really bad ,
kyle1234
Post by kyle1234 »
What is a good sounding exhaust setup for a 3.0L v6 pajero?
Overkill
Re: removed the cat from exhaust sounds really bad ,
Post by Overkill »
kyle1234 wrote:What is a good sounding exhaust setup for a 3.0L v6 pajero?
A cheap fix, take it down to your local exhaust shop and get them to add a piece of pipe in place of the cat, should only cost $80. 2.5 inch all the way through with a freeflow muffler sounds nice on the 3 ltr, add a nice set of Genie headers and she can go aswell.
kyle1234
Post by kyle1234 »
thanks man will do i put a piece of pipe in where the cat was but with the biguffler at the back sounds shit, so u recon put something like a flow master in and will be sounding good. Is it quite loud like that?
Overkill
Post by Overkill »
kyle1234 wrote:thanks man will do i put a piece of pipe in where the cat was but with the biguffler at the back sounds shit, so u recon put something like a flow master in and will be sounding good. Is it quite loud like that?
Yeah get rid of the factory one and add a flow master type and you will get the performance increase and it will still keep the "ricer noise" from being too great. Have a good chat to the guys at Pitstop or Midas for options on Mufflers.
u13turbo
Post by u13turbo »
Im wanting my 2.7td terranos exhaust to be louder, but cant afford a full through, Do you have to have 2 mufflers for wof? what could i do?
mud_slinger
Post by mud_slinger »
keep saving :wink:
its best to do it all at the same time, can work out cheaper than doing bit here bit there. no you dont need 2 mufflers only reason for a muffler is to quiet down the exhaust. mine has one which is in the middle
needs more curry
0272593533
panadero
Post by panadero »
ha ha ha , mine has 2 3/4 inch exhaust system, i took muffler and cat out and put 2 cobys in and she sounds mint!!!!
uptomynutsinruts
Post by uptomynutsinruts »
I cut the muffler out of my kzn130 and it sounded real throaty with a nice turbo spool on top and still passed warrents, wasn't loud at all, depends on which engine I guess
HARD L200
Post by HARD L200 »
i got a 2.5'' pipe on my 4d56t with only one of the shortest cobys i could buy and its pretty loud and the turbo whistles like hell thru it like a c-12 cat almost. but it has a very spine chilling growl to it i just love it.
Know me before you judge...my truck
Return to “Mitsubishi”
