18th/19th
mudslut
Re: 18th/19th
Post by mudslut »
This afternoon me and D.B started fittin the turbo and intercooler to my L200 ,got it runnin will finish it off tomorrow,sounded mean spoolin up tonight 8)
mudlva
Re: 18th/19th
Post by mudlva »
coxsy wrote:started the turbo fittment all fine till exhaust manifold came off broken stud bottom rear one, and stub end recessed in to head
found a few lose nuts while unbolting the manjfold that heat shield is not such a good idea
gutted thats going to be a hard fix start appling the crc
hollie
Re: 18th/19th
Post by hollie »
Picked up my NEW car!!!!!!!!!!! Pulled out the radiator and spark plugs, will do more on it tomorrow when i have the energy. :D
Btw thanks Bolo
mudnutz
Ol' Green Coal Range
Re: 18th/19th
Post by mudnutz »
When"s the lift happening, and the 35"s :?: :D
nachi
Re: 18th/19th
Post by nachi »
Just got over the flu and found the Hilux had a bit of that diesel bug.. ironic
Ripped out fuel tank, washed n dried, flushed out lines and fitted a new filter..
Can anyone recommend a good diesel additive to kill off any leftover traces of it?
Plan on fitting a clear filter before the main filter next week.
Not good when you find out about it up in the mountains..
Re: 18th/19th
still got the front exhaust pipe to remove, drain the sump, remove that, TDC ,then injector pump off,
all i have to do is everything :D
muskie
Re: 18th/19th
Post by muskie »
hey coxsy you are at almost exactly the same stage as me, but i have manifold on and my sump off, managed to find a fitting for sump $30 bucks!! weld in this week, made up an aluminium airbox and pod filter "mock up" to see if it will fit.
muskie
Re: 18th/19th
Post by muskie »
wopass wrote:well that was easier than i thought it was gonna be... didnt have to change much at all, change brace brackets and shorten tube a bit... doneburger!!
have to go get them dirty now :mrgreen:
wopass, did you buy the stainless tube from hamilton?? is it 3'' and where did you get it, ideally i would like some 4'' but cant find any..
Lynx
Re: 18th/19th
Post by Lynx »
mudslut wrote:This afternoon me and D.B started fittin the turbo and intercooler to my L200 ,got it runnin will finish it off tomorrow,sounded mean spoolin up tonight 8)
Pics :evil: :evil:
Started on my column for my orbital, rebiult hydro pump, took ram apart for some slight mods.
Cheers Daniel
petefj40
Ms Daisy
Re: 18th/19th
Post by petefj40 »
The two snorkels are looking mint wopass. Well done! :mrgreen:
Well. Had an awesome day Saturday at Springs Junction. The weather was wet, the tracks boggy as!! The company was cool. Couldn't have asked for a better time. Thanks for the invite Nathan. Anytime you want to do it again? I'M KEEN AS!!!!!! :mrgreen: :mrgreen:
Re: 18th/19th
found a few lose nuts while unbolting the manifold that heat shield is not such a good idea[/quote]
gutted thats going to be a hard fix start appling the crc[/quote]
all i have to do is everything :D[/quote]
hey coxsy you are at almost exactly the same stage as me, but i have manifold on and my sump off, managed to find a fitting for sump $30 bucks!! weld in this week, made up an aluminium airbox and pod filter "mock up" to see if it will fit.[/quote]
brought a angle drill attachment to get broken stud out , but no reverse drills at home, :( monday for that now let the crc work
wopass
Re: 18th/19th
Post by wopass »
muskie wrote:wopass, did you buy the stainless tube from hamilton?? is it 3'' and where did you get it, ideally i would like some 4'' but cant find any..
yes 3" no i didnt buy it from hamilton....in fact i didnt buy it at all :lol:
i have mates in the right places :wink:
but if you wanted to buy some ring steel and tube as they have all that stuff and about the best prices.
phraza
Re: 18th/19th
Post by phraza »
did a couple more paper roads with Lincoln, Caleb and Louis today, was pretty wet. I think next on my list to buy is a set of muds :roll:
Couple pics:
2WD 06 Hilux... for now
mudlva
Re: 18th/19th
Post by mudlva »
after crc thought about applying a little bit of heat from a brazing torch being cast iron a little heat directly onto the stud should be fine not to much mind
using the principle that when you weld a nut onto a broken stud that the heat that is put into the stud helps to unfreeze it as well then soak the hot steel with lots of crc
good luck
mud_slinger
Re: 18th/19th
Post by mud_slinger »
blew the seals in my clutch slave :wink:
needs more curry
0272593533
Re: 18th/19th
there is no stud end to weld too :roll:
RJT
Re: 18th/19th
Post by RJT »
mud_slinger wrote:blew the seals in my clutch slave :wink:
You get back alright? Was choice till it crapped out :wink: . While I remember, I forgot to grab that radio back off you too.
2008 R51, 2.5TD. 265/70R17 R/T's, 1.5" Rancho lift, Ironman snorkel and Deluxe winch bar, SCA 12,000lb winch and 9" LED spotlights, Kings awning, Alpinestar roof box, GME TX3100 UHF.
lincooln
Re: 18th/19th
Post by lincooln »
Well sat I went and saw Azhar Bamji, Just had a talk to him about having 4x4s at The 4 and rotary nats in Jan next year. He is wanting some trucks to attend the show on Saturday at ASB show grounds in Auckland and then on the Sunday have a course setup down next to the pits at Meremere. It will be a great thing for 4x4s as we get an audience of about 10000 or so. :D
So is anyone keen? It will be run through the NorWest club as I am organising it but we will need more trucks than just our club. Also I need ideas on what kinda course there should be? I was thinking some speed sections, bit of mud. We have about a football worth of space to play around with. Also anybody know digger Drivers and water tank places willing to help out?
Then today slept in , took it easy got board and went wheeling a bit, went to a couple of cool unformed roads, just too wet and slippery. will have to be once it dries out a bit more.
Good weekend :D
Lubrication Specialist
Lubrication Engineers
mudslut
Re: 18th/19th
Post by mudslut »
Drove the L200 home from the workshop tonight to test the turbo fark it goes good,still got to chop a hole in the bonnet and fit scoop and wire up intercooler fan and advance the injector pump timing should go even better then will post picks tomorrow
flyingbrick
Re: 18th/19th
Post by flyingbrick »
Been viewing open homes all weekend with the Mrs. Had our offer accepted on a really nice place and it goes unconditional in ten days time! Its our first home so we are both :mrgreen: :mrgreen:
mud_slinger
Re: 18th/19th
yea mate got back in one piece, should be back out soon as hopefully. yup i got ya radio. i forgot bout it too. wat part of town you live in? any pics of the day??
needs more curry
0272593533
FORGE1
Re: 18th/19th
Post by FORGE1 »
haha know the feeling.
mud_slinger
Re: 18th/19th
guess it was due to go. unfortunately decided to go in a nice deep hole.
are they rekittable or is buying a new one cheaper? can you remember wat you paid for one?
needs more curry
0272593533
FORGE1
Re: 18th/19th
Post by FORGE1 »
Yeah mine went just after I got out if a deep hole.
It was only $30 for a new slave cylinder on my Bighorn that was with a discount though. From memory he said its about $50 retail. He did say the Bighorn ones are more than your average one.
As mine had done 280kms I thought I may as well just get a new one.
mud_slinger
Re: 18th/19th
awesome. wer bouts did you get it from?
needs more curry
0272593533
FORGE1
Re: 18th/19th
Post by FORGE1 »
mud_slinger wrote:awesome. wer bouts did you get it from?
I got mine from Repco. It was the silverline (I think thats what its called) brand. Its the green and white box.
mud_slinger
Re: 18th/19th
mint as sweet ripco here i come
needs more curry
0272593533
mudslut
Re: 18th/19th
Post by mudslut »
mud_slinger wrote:mint as sweet ripco here i come
Try Bnt i would say they would be cheaper :D
mud_slinger
Re: 18th/19th
cheers, was considering giving them a try :wink:
needs more curry
0272593533
safaripete
Re: 18th/19th
Post by safaripete »
went and looked a vn commodore donor for the zook today
pick it up next sat 8)
