No big bumps, no jumping it no BS in any way, and all the dirt is just from driving around east side streets.
This is one with the wheel off I managed to find a swing tow truck to get the pos home.
DieselBoy wrote:Shiat!!!!
Thats the same bus that lunched the Center diff a while ago?????
niblik wrote:holy fawk cuz!!! what the hell???
Sadam_Husain wrote:niblik wrote:holy fawk cuz!!! what the hell???
x2![]()
what let go, did the ball joints fail?
vvilly wrote:so is that the two of us with the same thoughts now Grant
albundy wrote:Note the brand of vehicle
UBZ wrote::shock:![]()
very lucky indeed
were they OEM ball joints or aftermarket replacements?
Hi Mike
Thank you for contacting Toyota New Zealand.
In reviewing the photos and discussion on the Off Road Express forum, we can certainly understand your concern. Please be assured that our Technical & Product Specialist has reviewed the information you provided.
We wish to advise that Toyota New Zealand have not been notified of this being a regular occurrence with the Land Cruiser Prado. In looking at the photos that have been posted, the vehicle pictured appears to have modified suspension, which may have contributed to the issue. It also appears that the failure has been caused by a ball joint failure. We are sure that you are aware that ball joints are required to be inspected as part of a Warrant of Fitness inspection. However, it is difficult to comment further without knowing the service history and conditions the vehicle operates in and without the opportunity to physically inspect the vehicle.
We would recommend that the owner take this vehicle to their preferred Authorised Toyota Dealer, who will be in the best position to inspect the components, undertake the necessary repairs and report back to Toyota New Zealand if necessary. Contact details for Toyota Dealers across New Zealand can be found on our website at http://www.toyota.co.nz/DealerLocator/DealerLocator.htm.
Thank you again for bringing this to our attention and for the opportunity to respond.
Kind regards,
got a couple of reports of wheels falling off prado's . Like the whole area that holds the ball joints on. You can view on nz 4wd forum offroadexpress with photos.
http://www.offroadexpress.co.nz/Forums/ ... 40&start=0
a little bit scary. if that happened at open road speed limit, deaths could occur.
KIWI_TERRANO wrote:Bit off subject but is your snorkel a custom one??
Couldnt put a pic up could you
