carpet removal gone wrong!
jakwoo39
Post by jakwoo39 »
a few months back now i removed the carpets from my landcruiser and decided to under seal where the carpet used to be as i had seen it done on mates trucks.
i bought the CRC undersealer and painted it on the inside of the car, the trouble is that it never went hard so every time i touched the floor the undersealer would come away on my hands.
so i went and asked the guys who i had seen it done in there trucks and they used the kahguard from cookies toyota so i got that and painted over the top and it did go hard. BUT it melts again under heat from gearbox ect
so does anybody know how to either remove this s**t or know where i might be able to get some vinyl or something similar to cover the whole floor again?
Nivapulledout
Re: carpet removal gone wrong!
Post by Nivapulledout »
Hi mate yeah try mineral turps
pruggerdore
Post by pruggerdore »
I just did mine with "hippo" deck liner, its a 2 part mix so goes real hard and durable.
would suggest putting a couple of heaters under truck for a while to soften it as you say it softens with heat and use a scrapper to remove what you can then get the rest with rags and turps, kerosene or even paint thinners if it dosnt want to move. then start again. find one of the products used for coating ute decks with. expensive but awesome results
mudslut
Post by mudslut »
There is not going to be a nice way of removing it,wax and grease remover,turps or petrol and a shit load of rags and a scraper is the only way to do it.If you use underseal again make sure its rubberised/paintable not bitumen based,bitumen based does not harden heat and solvents melt it
kbushnz
Post by kbushnz »
Heatgun (not too hot) and scraper...
Then solvent clean.... NO HEATGUN.... :mrgreen:
And plenty of fresh air....
Calvin
DKZ
Post by DKZ »
What about going in the opposite direction and trying dry ice?
Works wonders with sound deadening.
Currently driving: 2000 Nissan 200SX. and 1988 Nissan Safari
A bullet may have your name on it but shrapnel is addressed "To Whom It May Concern,"
jakwoo39
Post by jakwoo39 »
DKZ wrote:What about going in the opposite direction and trying dry ice?
can anybody buy it and where in dunedin.
and does anybody know of anything i could just put over top :D like perhaps rhino linings or similar?
or does anybody have any of that vinyl stuff that some landcruisers have on the floor that they want to sell
1nzsafari
Post by 1nzsafari »
hi palmers mechanical ph 4710516 do rhino lining,or i could make you a new vinyl floor, it would be sewn not moulded like the factory ones cheers tim
tallsam66
Post by tallsam66 »
You can make ya own dry ice if you have a large CO2 extinguisher.
Make a cardboard tubeup that fits over thehorn of the extinguisher.its got to be quite long ....point the horn into the corner of acardboard box with a rag in the corner ...gently squeeze the trigger....dry ice will form like snow ...wearing thick leather gloves crush it in ya hands to form ice....not as good as the pellets you can buy but is a fun way to make it.
Be careful dry ice is -40 C it will burn you real fast.
Stevo Magic
Post by Stevo Magic »
I'm so glad I came across this post, I will be ripping the carpets out of my new motor soon and was planning to do the same thing with the first suitable thing I saw... could've been in the same boat!
Good luck getting it sorted :)
jakwoo39
Post by jakwoo39 »
yea definatly go to cooke howlison toyota and buy the proper Kahguard stuff it costs the same and it actually works 2 guys at work have it and theirs has gone hard and looks good
juz
Post by juz »
Use Rhino or Hippo liner, Have done decks in it and its a two Pack product so goes hard as and isn't solvent or heat sensitive. That Kahguard stuff is still quite solvent sensitive if I remember right. I wouldnt put anything over top again, the bottom stuff is always going to affect the top coats. Will never go hard, best bet is going to be scraping it off then attack the leftover bits with, turps/thinners/petrol. Taking it off is gunna suck. :D
Oh and try Rainbow paints(Dndn) or Coating Supplies(Invers) probably cheaper than Cookes
http://www.smitsgroup.co.nz/p1643v0/Dominion-Sure-Seal/Dominion-Sure-Seal-Hippo-Liner
Return to “Toyota”
