d21 project with no name
- muddyhilux
Re: d21 project with no name
yeh bro it is,thats y i havent been on here updating much cos it just makes things worse
,n yeh,kinda.my plate just says 15x10s,not the offset so yeh,n yeh i maybe able to do something but i just dont wana have to deal with him any more to be honest,im just gona get this stage of oscars truck done then after that move on and start a fresh somewhere else and idealy someone with a shop,that way i can find them 5 days a week ya kno
- Sadam_Husain
- Angry bird
Fark your cert experience is pretty different to mine although I only had an engine transplant certified, I rang the guy I used down here and he said I could bring the truck around the next day if I liked so I drove over there the next day, he lifted the bonnet and spent about 15-20 seconds looking at shit and dropped the bonnet again and said the cert plate will take about 2 weeks to arrive, 2 weeks later he popped around and stuck the plate on
- muddyhilux
yeh thats what i usually get but not this time,and its ne time to many
so someone else can now benifit from my business
What is wrong with the wheels???
- muddyhilux
mine are 15x10 -70s (maxium allowed is 20% of with width so maximum of -50.4)
- muddyhilux
ok,for anyone still out there watching
,IT NOW HAS CERT
took truck into freelance automotive thismorning,lance went over it with a fine tooth come,road tested with stop watch etc,all the things that should have been done by previous certifyer,and done,ws happy the handbrake ws safe and worked,happy with all other work completed,and very sharp price,to all guys i recomended previous certifyer,disregard that comment,my appologies,USE THIS GUY
Good news, well done.
Ph 0212078472
Ph 0212078472
awesome mate that's great news.
Oscar must be stoked. yell out when you want to go for a spin
C.
C.
LR110 ..... LJ50 project
- muddyhilux
cheers,yeh were eally both happy as,and yeh will do chris,ive just taken delivery of my other mates fj40 with 350 chev,whole truck needs a rebuild butim just goin over the basics at the mo then i be taking it 4 a blate up muriwai id say and thatl be a good test for oscars truck so will let you know when itll all happen
- muddyhilux
well trucks been on the road year and a half,done a handful of trips and oscars really happy with the rear end flex,and man does it flex,got it on some awesome angles and she's stable as
now though 90% of parts have been collected and she's going under the grinder again.3.8vr commodore and sas with widened hilux axle to match rear end width along with pushing it forward.body lift will be reduced to minimum required to fit,few deck mods as current set up wasn't as user friendly as hoped.winch and front bar and full exo cage
with any luck all will be completed by early october
pics to come
pics to come
- muddyhilux
couple of spring and axle fitting pics
possible position of wheel
ifs hubs and rotor moved with snr spacer,so easy
new xmember i fabd up after the one we had just wasnt right
weight on springs
as it sits from side
and front
mounts and shackles for rear of front leafs
new flywheel
with weight
without weight
and front surface,got to love new parts
and new 14" travel shocks for the rear
as she now stands with no bodylift
at the back of last pic you can see rear shock tower in place
better pic of approach angle
eng at height in eng bay
close up of mounts,both sides the same just mirrored
new deck,yes with a big hole
this is what fills it,sits half under half over the deck to keep weight low
and what it'll look like when its got the toppings added
shock x member welded,shocks in,where box will sit and deck frame shot
all eng mount brackets ready to be bolted on and zapped to chassis
start of rear sump conversion
throttle body moved with new pipe / bracket
reduction box parts and dual transfer adaptor ready to be put together
start of bell housing cover plate
steering box with plates and crush tubes,just needs to be dropped down 15mm and zapped
weight on springs
and front
new flywheel
with weight
without weight
waiting for pics
Oh i was hoping you were going to SAS with origanal passenger side transfer case.. I want to do it to my terrano, just no diffs around that use passenger side transfer.
Very nice navara tho! how did the front end hold up with the weak IFS?
- muddyhilux
yeah yeah,got to do some work before pics go up
,and yes,that's the problem with the LHS output.could be done with a chop and flip of a front diff but a lot of work,that's why were doing it this way,and parts easily available.and as for front ifs no worries to date.never blown anything.but truck isn't pushed to hard usually and only has standard motor so yeah.probably wouldn't hold up to the commodore
- muddyhilux
well made some good progress for the week.all ifs crap removed and in the bin,main bits of the ifs brackets removed so we could start eyeing things up (unforunately i cant grind all hours of the night in suburbia
then got into it sat night with the boys,rolled the front end under and she's looking good.with it all sitting at ride height the vehicle should now sit almost completely flat as instead to nose down and the approach angle is looking really good,all pics in post above
also looking like we'll be able to remove almost all of the body lift which is really going to help with the height thing
- muddyhilux
few more pics added in page 5,you can see in the photos how much hook the chassis has at the front so x member we had just wasn't right and would have meant losing spring radius length,so I fabd up a new x member which you can see sits flat with front of truck and gains us 40mm of spring radius length which were happy with.oscars removed everything engine related from motor,he's also picked up a new air tank each for his truck and mine,bottom photos is how it sits now on all 35s.height of truck body is at 1950 and that like I say should be coming down to 1860 after body lift is removed
oh and dont look at the weld in the centre of the x member,bloody wind
.i was in overalls gloves and helmet and didnt relise the wind behind me had oicked up,after 5 mins of thinking my welder was playing up i took of mask and gloves and what would ya know,its bloddy blowing a gail
,so that needs grinding off and redoing
That new x member looks much better mate , definately looks better sized for the truck anyway and wont bind up on the inside now like the old one did ... bet your glad Oscar and yourselve decided to scrap the other one !! Good to hear and see more improvements / progress its coming along nicely !!! Keep the pics and the posts coming , I have " subscribed " to this thread now to keep up with ya guys
- muddyhilux
haha cheers mate,we are definitely both happy,hangers and rear mounts should be made up by the end of the weekend and ready to zap in the following after motor and box are back in.you'll have to come round again for the next round of laughs
- muddyhilux
well been almost a month,been a bit slack and actually doing hours at my job instead of on the truck
photos added on page 5 of new rear mounts and shackles for the front springs,planning to zap them in this weekend so that'l have her on all four again.
also picked up the new flywheel which we tracked down through bnt,$680 but still cheaper than going to aus and far these middlemen so oscars happy,only thing now is ive got to work out weather we need to run the counter weight or not and buy some new bolts to put her on with along with collecting clutch next week
gearbox xmember is in and holding up the box but needs 2x inside chassis brackets added and then 4x holes drilled,front edge ive got to fold up and a slightly bigger scallop for the oil drain plug and she'l be sorted
steering we've decided to just rip of the nissan and use a surf box so we don't need a custom steering arm to go nissan to toyota,again this will hopefully go in this weekend and so all steering will be functional again
motor position is also looking good and shouldn't affect travel at all and will sit nice and low
- tomsoffroad
- Flopsie
You'll end up with a Narvara like ours. Only Narvara bits left are the chassis rails and cab
Nice work tho fella. These things tend to fight all the way
- muddyhilux
tomsoffroad wrote:Only Narvara bits left are the chassis rails and cab![]()
you aint wrong there
and cheers mate,it is coming along nicely at the mo,with any luck motor will also be running by next weekend which were both really looking forward to,that'l give us the extra motivation to really get the job done.not to mention were hoping to have his and mine back on the road before xmas for a decent trip away
good progress guys.
what yous doing with clutch? bigger master or sleeving the slave?
I havent had and luck yet finding a shop to do the sleeve.. only rung 2 so far but both were little help to say the least
- muddyhilux
supose i should update
,been a bit slow,motor and box still out,just got tidy up a couple of things with clutch then she'll go back in,old trays been removed and im currently fabbing up a new version,that'l be on by end of the week(got a week off work so time to do some work),back end has had 50mm lift blocks aded to help it match up with the tall front end.we've been taking our time looking at getting motor and box in best place but looks like motors just too far forward so looking to do dual transfer case to push things back,that should give us alot better angle in the front drive shaft,possibly save us putting a 2piece in the rear and it'll make it easyer to crawl around the car parks looking for a spot
,will get pics up on page 5 asap,oh and also fabed up new rear shock xmember to get the shocks at a better angle,dive tank purchased and just getting ready to mount to new deck
oh and also just getting drawing sorted then roll bar can be bent up and also rear mounts of front springs are g clamped in and just waiting to be welded in now we've got their position sorted
- muddyhilux
ok finally made more progress and got some final measurements worked out.truck now has no body lift at all thanks to sas and good approach angle.rear shock tower is made and just sitting on the truck ready to be welded in when i get a chance.eng height is set and have just finished making eng side of eng mounts.shes definatly getting dual transfer cases which im picking up the adaptor for later on this week.and as said almost all measurements are now worked out so its just a matter of building the thing now,all going well shes ready for xmas (THIS YEAR!)
all pics on page 5
all pics on page 5
you do some bloody tidy work
who says inlaws are shit, your bro-inlaw must be stoked
- muddyhilux
cheers mate,and yeh hes bloody stoked ae,especially loves the no body lift part,the trucks gone from tall and a bit unproportional looking to low and as fat as pos
looking great
puts my booty fab to shame
must come out and have a real look ..
- MNC
muddyhilux wrote:ok finally made more progress and got some final measurements worked out.truck now has no body lift at all thanks to sas and good approach angle.rear shock tower is made and just sitting on the truck ready to be welded in when i get a chance.eng height is set and have just finished making eng side of eng mounts.shes definatly getting dual transfer cases which im picking up the adaptor for later on this week.and as said almost all measurements are now worked out so its just a matter of building the thing now,all going well shes ready for xmas (THIS YEAR!)![]()
all pics on page 5
Looks mint! Any thoughts on shortening up the rear tray and chassis back to the rear shackle mounts?
Nice work
- niblik
- Sausage Shack
i wouldnt bother shortening the rear chassis or tray.. looks well constructed and up out of the way.. also a handy size..
- muddyhilux
cheers for the comments guys,yeah flick me a text when your free Chris,your welcome any time and na mate,your works nothing to be ashamed of mate,i mite make things look good with big fab jobs but look at any panel work ive done and you can see my work to be ashamed of..everyones got there strong points.and no deck and chassis will stay as they are,never had problems getting caught on chassis and deck is behind the departure angle so will be very hard to make contact with.and also bang on nibz,we wanted at least some usable deck
,were not quite there yet but were going to look down the path of putting the spare wheel on a pivot bracket so it can be stood up when there's extra gear and the dive tank may end up along the front of the gear box yet,not quite there as I say
