Sadams Flatdeck 6.0 litre chevy, runs & pulls 3rd gear skids
Re: Sadams Red Flatdeck tidy up and new engine
Rock on baby
- Sadam_Husain
- Angry bird
rokhound wrote:Rock on baby![]()
I was trying to find some of that flash orange paint for the chassis but had to make do with plain old black
Nothin wrong with good old chassis black
Didn't barbie drive a jeep??
Where you up to with this Marty?
BUMP Update time
- skid
- Tyre Man
Bolo wrote:BUMP Update time
hes been bush for last week and a half
that a good enough update dude
Time for an update on this one.
Where are you up to ? is it road legal yet?
- Sadam_Husain
- Angry bird
mylux wrote:Time for an update on this one.
you must have known I've been up to no good lately, finely got everything back from the panelbeaters at the start of Feb about the same time I busted my right shoulder out in the bush so its been a slow start to the year. Sig did a bit more playing around and machineing etc and got the clutch fork and release bearing to fit into the bellhousing with the twinplate clutch and snuck the engine and gearbox back in the chassis without even inviting me over to drink a few Tui's and watch
Now you mention it I did see a couple of pictures of you with ya arm in a sling.
Bout time to orginise those Welly boys for another working bee I reckon.
It would be good to see some pictures.
Go hard
Richard
Go hard
Richard
- Sadam_Husain
- Angry bird
There's bits scattered everywhere so I cant do a lot of photos, the cab is in my shed, the chassis and engine is in Sig's shed an hour away and the deck is on loan to a mate with a 70 series he brought without a deck last year
Sorry Marty I found your guards and bonnet ...they might fit mine
. you can have my unpainted ones
Seriously ... whens the next working bee
Sadam_Husain wrote:There's bits scattered everywhere so I cant do a lot of photos, the cab is in my shed, the chassis and engine is in Sig's shed an hour away and the deck is on loan to a mate with a 70 series he brought without a deck last year
Man thats looking great.....Nice new clean cab there sir....
Don't have 4wd.
- Sadam_Husain
- Angry bird
Some more updates, pics of the engine and gearbox bolted into the chassis
we were able to use the captive mounts I'd had made up for the old engine a couple of years ago, they have been shifted back on the chassis about 60-70mm coz the later chev engines are a bit shorter without the flange around the rear of the block.
The later engines are a 4 bolt pattern for the engine mounts instead of the old 3 bolt pattern so we bolted plates to the old engine mounts and redrilled them for the 4 bolt pattern. The truck is now setup with engine mounts that can swap between std 350's and LS engines without having to modify anything again
A couple of nights ago Skid rallyed all the boys together and they came around and picked up the cab, loaded it onto the trailer, drank all my piss and took it out to Sig's place and we mounted it back on the chassis
Cab moving Thread Here
Jerry wrote:Only had Camera Jnr with me![]()
Mark knows about this![]()
Reflectoskiddy
Looking good,
keep up the good work
Nice tidy work. Love the tool box!!
- Sadam_Husain
- Angry bird
Got a bit of shed time today, stuck the fuel tank in and hooked up a few linkages and odd bits and pieces, Sig's been turning a big engine loom into a small engine loom
Sadam_Husain wrote:Got a bit of shed time today, stuck the fuel tank in and hooked up a few linkages and odd bits and pieces, Sig's been turning a big engine loom into a small engine loom
How Is the truck going
ford ranger wildtract and sj.
slowly
- Sadam_Husain
- Angry bird
Been a bit of exhaust work going on in Sigs shed the past couple of days, LH side exhaust is built and RH side is built up as far as the back of the cab and stopped there coz we couldnt find the missing flange despite turning the shed upside down and searching everywhere for it
its a twin 2 1/2" system down each side exiting just behind the rear wheels, after it looking really tight to get the pipes down the inside of the chassis rails and past the PTO on one side and past the 4wd vaccum accuator and transfer case on the other side it worked out a pretty good fit.... nice work Mr Sig
Will need a small working bee in the near future to lift the cab back off to swap the gearbox out for a spare one and setup the clutch slave cylinder and sort out a few underneath bits, dtba
Nice build, truck is progressing nicely, looks very professional I like these type of build threads, keep up with the good work.
Cheers.
Cheers.
Nice exhaust work ! Looks like it should be well out of the way of getting bashed.
Looks really nice!
One question though, aren't you meant to join the twin exhausts else it will sound like two inline 4 cylinders with weird ign timing?
Balance Pipe, pretty sure you do need one, will ask my mate who used to own Midas.....Slideways wrote:Looks really nice!
edit: Balance pipe not "needed" but will give better performance and nicer/ricer quieter sound.....
- Sadam_Husain
- Angry bird
You can join them into a 2 into 1 but then it isnt a twin exhaust anymore or you can put a ballance pipe in but they still sound fine without one. The truck used to have a 2 into 1 with the 350 and my 40 series is a 3" 2 into 1 and I havent had a twin pipe system before so I thought I'd try twin pipes this time around
both sides are built now and only need the o2 sensor fittings put in and some mounts made up for the back. Didnt have any clearance problems around the back diff other than having to route the drivers side pipe up over the arm for the brake proportioning valve
- niblik
- Sausage Shack
veddy good veddy noice....
lookin the shizzle nizzle..
as for balancing pipes, i dont have one on vomitron.. seems to drive fine and sound ok on song..
- Sadam_Husain
- Angry bird
niblik wrote:veddy good veddy noice....![]()
Yep shes starting to take shape now Nibz
getting excited we are!
going to be very sweet once done, i feel a trip to whanga road is needed to test it
