early (gen 1) mitsubishi paj front diff wanted!!!
i need a front diff out of a gen 1 v6 man pajero. must be 5.29 ratio. 8" diff i think. anyone able to help? i have a 5.29 gen 2 front diff if anyone needs one? from my understanding it will only fit into a diesel or auto as its a smaller diff. please correct me if im wrong J top...
Unfortunately there is no such beast as a 5.29 8 inch front diff, high or low pinion. 5.29 7.25 inch, yes but these will not take the ARB.
To get a 8 inch 5.29 as JTop siad, do it yourself, get a low pinion front end assembly from a V6 which had the 8 inch diff housing (4.8 ratio thou) and then get a 5.29 crown wheel and pinion from the rear of a gen 1 Paj which had an 8 inch rear diff and shoehoen that into the front....... Along with your ARB
my understanding was that the 8" was stronger. i have read the stuff on outerlimits about the reverse cut gears and 30% stronger etc. should i just fit the 7.25" 5.29 front diff i have? im all confused again! ether way ill be keeping all the diffs. just not sure what ones will be going into mine.
