terrano steering problem,
brakes-shocks-lockers-etc
u13turbo
Re: terrano steering problem,
Post by u13turbo »
Im currently trying to sort my truck out for an alignment, Im finding it bloody difficult to figure out what ball-joints are cut and what are not. Today i replaced my outter passenger tierod, so no since i had my truck i have done, both passenger tierods, draglink, and idler arm(My newer idler arm seems shorter that my old one, so the draglink sits closer to the chassis? is that a big issue?
Just saw the link posted, they saw aftermarket draglinks are shorter.... Thats why my brace doesnt fit, and i had to pack out with washers, i think to make it work properly i will need a standard one, with decent bushes. Can you buy decent bushes anywhere? because my last set from BnT were so soft, after about 2 weeks the were completely buggered.
I just read through 10 pages of that link and looked at the last 6pges of photos :D It has made me want to get one of the custom drag-links from sketchy even more, From what they say, if you use those tractor tie-rods and the custom drag-link with braced idler, its dam near invincible.
sibainmud
Post by sibainmud »
u13turbo wrote: Can you buy decent bushes anywhere? because my last set from BnT were so soft, after about 2 weeks the were completely buggered.
Same issues here too.
Go genuine Nissan idler bushes, they are dense nylon and last well.
Stay away from the cheap aftermarket Tie Rods, Idler arms, Idler shafts.
Buy a second hand genuine idler shaft and arm, fit new bushes and all will be sweet.
Now these cheap Tie Rods, (rule of thumb, you get what you pay for :roll: ) They last 2 or 3 trips then they have enough play in them not to be wof'able and unsafe.
I now have a small box full of shot ones.
I'm now looking at getting genuine Nissan Tie Rods to see how long they will last.
Keep us updated :)
u13turbo
Post by u13turbo »
Keep us updated :)
Righto cheers for that, All my new tierods are after market ones from Bnt... so guess they wont last long, How much are genuine ones? Im going to have a look at a petrol auto terrano for a few parts i need (handbrake cables, rear calliper, windscreen) I better add idler arm to the list, Get it sorted properly.
was suggested to me, that maybe you guys could see if massy Ferguson tractor tie rods fit.
kiwipete
Post by kiwipete »
coxsy wrote:was suggested to me, that maybe you guys could see if massy Ferguson tractor tie rods fit.
Yes they do fit, the South African guys use them, but you have to re machine the tapers for them etc as they are a different size, but at least they sit square on with the threaded shaft section being pre bent a little. I have some pictures but I do not remember the website. I see they have done a similar trick with the centre link too.
Ph 0212078472
u13turbo
Post by u13turbo »
http://www.nissan4x4.co.za/forum/forum_ ... PN=0&TPN=1
Thats the site there, basically has all the strengthening mods for terrano steering.
u13turbo
Post by u13turbo »
To get the genuine bushes, Am i best to get them from Cockram Nissan? or is there somewhere else in ChCh?
sibainmud
Post by sibainmud »
Welcome to ORE.
Search Terrano steering. There is a few good threads covering this subject.
There are some simple tests and remedies too.
What part of the country are you from?
Go into private messages and put your location in your profile (help could be just around the corner)
u13turbo
Post by u13turbo »
madozy1 wrote:cheers mate im in old shaky city christchurch living in woolston anyone with any advice would be great this is the first 4x4 i have ever owned so im in the dark clueless
Mine wonders all over the road atm aswel, but i know thats because my alignment is way out, buggered bushes, and both lower balljoints are buggered. If you had an alignment done recently, they should of really picked up the problem..
kiwipete
Post by kiwipete »
madozy1 wrote:took it in for a wof today found out both bottom ball joints stuffed and inner tie rod stuffed so will know after the weekend if it steers any better if the parts come that is also my wof person said the ones who did the alligment are useless i wont say what company it is he also recomended i take it to the 4x4 upgrade place on brougham street in the future
Or you could take it to Chamberlains in Sydneham, they are very good on my Terrano with steering issues. I would recommend them over any 4x4 place that has little knowledge of Terranos.
Whatever you do, do some homework first, and I think you should publish the name of the outfit that did your wheel alignment so others know to avoid them.
Ph 0212078472
u13turbo
Post by u13turbo »
kiwipete wrote:and I think you should publish the name of the outfit that did your wheel alignment so others know to avoid them.
I agree. I took my truck for an alignment and first thing the guy done was jack up the front and found both bottom balljoints and top bushes were fucked.
nizmo
Post by nizmo »
we do wheel alignments at work (www.championauots.co.nz) we align all makes and models and if there is any play in steering ect we wont do a alignment, obviously they must of had a hard time getting the toe set correctly with worn parts, all adjustments are important so we like to get every thing bang on, also road test after to check for pulling and to make sure steering wheel is straight,
Roenut
Post by Roenut »
if anyone is still experiencing this prob, go have a look (dare i say it) on the NPORA site. kiwipete has a decent build thread on his terrano, and made up an idler arm brace and a draglink/tierod stopper that got rid of bending probs. he has good pics up of them
i used to have a terrano and didnt have probs as it was a 95 with the bigger tapers.
if worse comes to worse, convert it all to the bigger taper.
my 2c...
Less Traction More Action!
previous vehicles - commodores, bmws, subarus, 1kz surf, d21 terrano.
ln60 surf, current - kzn130 surf
