New Turbo fitted, Take 2.
Got my DSR430 replaced this weekend with a GT35/TO4 hybrid, went for a quick spin and Im impressed at the power. Im currently running about 19psi but its hard to tell because im having trouble with wheel spin up to 3rd gear. was quite good to hear from my friend how much more power i had than his 1uz powered 130.
pics to come
pics to come
5L+GT35@21psi= 223RWHP
5L+GT35@30+psi= 287RWHP....
Great tow Vehicle!
Great tow Vehicle!
Re: New Turbo fitted, Take 2.
What happend with the dsr430?
Rob
Rob
its sitting on a bench in a workshop in whangarei, getting a rebuild and a new home probably.
Great tow Vehicle!
Great tow Vehicle!
Read your original post my bad
Rob
Rob
willferris
- Mr Mumbles
shame about those dsr turbo's eh,
there reputation seems to go with them everywhere
good to hear you've gone for a proper turbo
engine rebuilds are worth a lot more than the difference between a cheap turbo and a decent one
The DSR wasn't to fault, it was a combination of me stuffing up and wrong turbo application.
I would have kept the DSR430 if I could have found a smaller exhaust housing for it..
Great tow Vehicle!
Great tow Vehicle!
- KIWI_TERRANO
What sort truck motor is th?
wheel spin in 3rd
wheel spin in 3rd
I bet you double checked for foreign objects in everything
Best of luck with it. How are the EGT's now?
You'll just have to wait for the road to dry out to stop the wheel spin
KIWI_TERRANO wrote:What sort truck motor is this?
wheel spin in 3rd
This is my high boost 5L in a LN130
sibainmud wrote:I bet you double checked for foreign objects in everything![]()
You'll just have to wait for the road to dry out to stop the wheel spin![]()
What i realised afterwards was i have 4wd
But yes I triple checked, im also currently removing the sump to add a better oil return as I also think this was adding to the oiling issue. I thought it was big enough but i had a bottle neck
Sump removal sucks..
Great tow Vehicle!
Great tow Vehicle!
- KIWI_TERRANO
Sick skiding in 3rd....... Is it custom fabed?or bolt on kit?
Im looking at 5l hiluxs but know there gutless
KIWI_TERRANO wrote:Sick skiding in 3rd....... Is it custom fabed?or bolt on kit?
I used a stock 2L-TE exhaust manifold, Made an adaptor to suit T3, fitted a custom built turbo.. Has enough power for now.. Until i get everything else done.
Great tow Vehicle!
Great tow Vehicle!
- KIWI_TERRANO
manual fuel pump?
Sorry to jack your thread
yeah, stock 5L pump, getting a 12mm pump built as soon as money allows..
Great tow Vehicle!
Great tow Vehicle!
Kiwiterrano: Honestly as soon as I put my stock CT20 on to the 5L it had as much if not more power than a 1KZ, its a awesome conversion.
Great tow Vehicle!
Great tow Vehicle!
Right after fixing the oil return line my truck is running pretty much perfect, max EGT 500 deg.
The new turbo is quite big, gives everyone the fear LOL
Now next mission is to fit aqua-mist using pure methanol to provide more fuel at about 12psi. Oh and to utilize the cooling benefits LOL.
Great tow Vehicle!
Great tow Vehicle!
Throw up some pictures of the new set up Will!!
http://www.almo.co.nz
http://www.facebook.com/dsrturbo
willferris
- Mr Mumbles
Big Will wrote:Right after fixing the oil return line my truck is running pretty much perfect, max EGT 500 deg.
Ive never seen a 5L pump in bits but do they have a pressure sensor etc? Or do you need to get a boost compensator? sounds like a sweet build, with a lot of power, and like your pump is somehow tuned to perfection that its not over fueeling all the time. be keen to know what you've done to it.
Dayne; I wasn't able to get any pics over the weekend cause my wife had the camera and she was away, but i have tomorrow off and I should be able to get something..
Oh, and i might be needing something a little bigger for another project, but that's hush hush..
WILLFERRIS; hey mate, the 5L pump is a non compensated pump, it does puff the tiniest bit of smoke before the onset of boost but you cant hardly see it.
once you get the exhaust wheel/ housing combo sorted it cant over fuel once on boost just because more fuel it runs the more boost it runs to compensate because im not using a wastegate.
That and the fact my exhaust wheel is 6mm bigger than the stock on it is allowing my back pressure to be very very low by comparison.
I might have to invest in a mechanical locker, should sort the traction issue a bit.. On the gravel i had it light up on me in 4wd!! try that in a Terrano!! JK's!!
Oh BTW im looking at starting a small business fitting turbo kits so anyone with a non turbo diesel need convincing, come take my truck for a spin, a friend of mine is probably still giggling like a little girl LOL.. Oh and I am a mechanic by trade, 8 years in the job with diesel/petrol euros etc etc.. Just as a side thing when we can arrange time.
Great tow Vehicle!
Great tow Vehicle!
Big Will how are those pictures cumin along thanks
td27 with a steve murch turbo and 30psi would give it a run
TD power wrote:td27 with a steve murch turbo and 30psi would give it a run
'Like', Plus probs more reliable.
I be keen to see that Nissan vs Toyota, I give you ago in my KZJ71
Rebuilding and turboing the 5l in my truck so similar specs as you are doing are in my long term pipe dream. Have you done anything to the motor? thicker head gasket or anything? Can things be strengthened at all? How many ks are on it?
Pete
Pete
Didnt realize that this was the thread for 'my e-penis is bigger than yours'
Im quite happy with my results, and I never set out to build a race car just a tow wagon for my race car.. but if you want to be embarrassed come round I might even leave my trailer hitched on.
JK's
http://www.facebook.com/photo.php?fbid= ... =1&theater
Hope this link works.
JK's
Great tow Vehicle!
Great tow Vehicle!
Lynx wrote:TD power wrote:td27 with a steve murch turbo and 30psi would give it a run
Big Will wrote:I might have to invest in a mechanical locker, should sort the traction issue a bit.. On the gravel i had it light up on me in 4wd!! try that in a Terrano!! JK's!!
He was basically answering a question....
Meh.. I was actually saying that because a friend of mine has a TD27 in his terrano running a rather big turbo and massive boost and I sent that as link to him..
Great tow Vehicle!
Great tow Vehicle!
