niblik wrote:option 4...
Andrew1706 wrote:Op 4 with the hook pointing upwards
Sadam_Husain wrote:I thought we were doing opt 4 with 2 pieces of angle?
stinky wrote:looking good are you going on the Godley trip if you are i owe you beer and i will send it with them( dont like your chances of getting anything but an empty box tho)
stinky wrote:That camo safari you checked out for me
skid wrote:I went with option 5....................
Blair_ wrote:skid wrote:I went with option 5....................
Were do you get one of them from and cost??
suzolla wrote:also put more stain on the bolts
Pedro wrote:Blair_ wrote:
They have a roller bearing in them, the old ones just have the copper bush thing.....
Personally i would stick to the bronze bush, if roller bearing fails due to moisture in oil/grease then is will quietly eat the CV shaft, bronze bush is less likely to eat it way thru, they will get warm, sweat oil/grease and be re lubed. but if the truck well maintained and oil and hub freq checked particularly with a lot of off road work they should be good
my 2c
Pedro
wopass wrote:suzolla wrote:also put more stain on the bolts
and you dont want that!!!...
