ATTN Landcruiser owners!pls share yr exp.re PINION SEAL,BEAR
dr4lex
- Driver/Navigator
hi,all!as per my prev.post in toyota tread i am replacing pinion seals .diffs in place.73 cruzer 1991,1hz man,based in Albany.
i got both rear and front pinion seals out.
to put everything together i need to replace non-reusable crush sleeves which set preload in the pinion bearings.to get the sleeve out i need to pull the bearing out.
i managed to pull out rear pinion bearing without any tools,
but front pinion bearing wont come out ,bastard!
i smacked front pinion with a hammer throu a soft drift as advised by Simon,bearing did loosen a bit on the shaft,but wont come out anyway.
my book says use universal puller with fabricated legs(have a pic of one in the book)
IF anyone had experience pulling the bastard out and may be has a puller ,pls let me know
a puller from auto stores a not good coz too fat feet-there is not much space for them
hell knows how to attach pics,can see google map and youtube
option but not a pic
i dont believe a diff must be out of the car to change pinion seal,it is easier with diff out,but not the way i wanna go
wopass
Re: ATTN Landcruiser owners!pls share yr exp.re PINION SEAL,BEAR
dr4lex wrote:hi,all!as per my prev.post in toyota tread i am replacing pinion seals .diffs in place.73 cruzer 1991,1hz man,based in Albany.
wtf you pulling bearings and crush tubes for ??
just put the new seal in and re tighten the nut back to where it was before...
10 min job dunburger!
mudlva
wopass wrote:dr4lex wrote:hi,all!as per my prev.post in toyota tread i am replacing pinion seals .diffs in place.73 cruzer 1991,1hz man,based in Albany.
got to say second that why would you be wanting to do a pinion bearing and tube for no real reason.
if the bearing is stuffed then pull the diff and be done with it otherwise leave well alone
dr4lex
- Driver/Navigator
THE CRUSH SLEEVE CAN NOT BE REUSED,THATS WHY
wopass
dr4lex wrote:THE CRUSH SLEEVE CAN NOT BE REUSED,THATS WHY
realy?? ahh well your screwed then and have to pull the diff out...
to do a 10 min seal replacement job
have fun.
dr4lex
- Driver/Navigator
VERY HELPFUL,THANKS
Andrew1706
Seems you've been given some wrong information..
Unstake and undo nut, pull flange, pry out old seal, knock in new seal, redo nut up to where it was before, restake
9 times out of 10 you will not have to worry about any preload
Redoing the crush sleeve requires a bit more technical know-how and is much easier done out of the vehicle
dr4lex
- Driver/Navigator
THINS INFO IN MY repair manual and all over the web.
just wanna do things properly
so will have to make up a puller
oldblue
Andrews answer plus when tightening the pinion nut you may need to go a bit tighter untill you can just feel a slight tightness when rotating the pinion flange.or zero sideways movement.
kbushnz
Have a read thru this website to see what you are getting yourself into.
http://www.gearinstalls.com/
Have fun
Calvin
Have fun
Calvin
dr4lex
- Driver/Navigator
found tool number-09556-22010
looks like this http://toyota.spx.com/detail.aspx?id=346
dr4lex
- Driver/Navigator
have u done that before?all good since then?
oldblue wrote:Andrews answer plus when tightening the pinion nut you may need to go a bit tighter untill you can just feel a slight tightness when rotating the pinion flange.or zero sideways movement.
dr4lex
- Driver/Navigator
been there, also read toyota repair manual plus hayns one-
its not quite that scary, just need the puller
kbushnz wrote:Have a read thru this website to see what you are getting yourself into.
Have fun
Calvin
jeremy
dr4lex wrote:have u done that before?all good since then?oldblue wrote:Andrews answer plus when tightening the pinion nut you may need to go a bit tighter untill you can just feel a slight tightness when rotating the pinion flange.or zero sideways movement.
I've done this before (prado 8" rear). I don't know if it's "all good", but it's still working.
mudlva
kricky whats the shouting for??
you asked for advice we gave it and you didnt like it
this being the case why ask the first time
ive done dozens of pinion seals as mud and weed will wind there way past the seal, poped the nut out with the old in with the new and away ive gone
i think you are making a huge job for nothing personally
anyway its your truck do as you want
dr4lex
- Driver/Navigator
THANKS ALL
JUST wondering if they want me to do extra work and buy those NOT CHEAP
parts writing those manuals
oldblue
Fitted about a dozen ARB lockers and always changed the seal, no problems.
wopass
ohhh come on guys, he wants to spend heaps of time and money to replace his pinion seal (10 min job as we all know) by doing it the long and hard way that is reccomended all over the net and in the workshop manual... dont try to talk him out of it...
see my sig line at the bottom?? read it!!
SMOKEY
dr4lex, because you have asked and said please share your experience
, I will
, but before I do let me explain
, there are two ways of doing things
, the way the workshop manual says and yes they have to get it right or face allsorts of legal action
, or do it the way that has been learned and used by people who have through past experience found a way that although not 100% correct as in the manual is sufficient to do the job
.Now I don't know how to post it here but I wrote an article explaining in full how to change a diff seal and although on a Surf it will be the same for a Landcruiser, go to --- In the garage>> Toyota ---- rear pinion seal replacement LN130 Feb;24 2010. Or someone may post it on this thread. If you do do it the BOOK WAY you had better be prepaired to do a bit more reading and spend a few more dollars, because to reset the pinion bearing pre load correctly requires a re-build , according to the manufactures Workshop Manual.
NOW SMILE PLEASE,
FITZY.
NOW SMILE PLEASE,
FITZY.
Smurf
SMOKEY wrote:dr4lex, because you have asked and said please share your experience, I will
.Now I don't know how to post it here but I wrote an article explaining in full how to change a diff seal and although on a Surf it will be the same for a Landcruiser, go to --- In the garage>> Toyota ---- rear pinion replacement LN130 Feb;24 2010. Or someone may post it on this thread. If you do do it the BOOK WAY you had better be prepaired to do a bit more reading and spend a few more dollars, because to reset the pinion bearing pre load correctly requires a re-build , according to the manufactures Workshop Manual.
NOW SMILE PLEASE,
FITZY.
Coz I know YOU know what YOU are talking about, I'll link it for you, Fitzy.
The thread Fitzy is talking about.
http://www.offroadexpress.co.nz/Forums/ ... 22&t=20208
And everyone else is right too, you don't need to touch the crush tube unless you are planning to remove the diff head and reset the preload and backlash etc in the diff, which probably means you'll want new bearings and then you'll need to know how to set the diff back up properly. Not a job for the faint hearted or those that don't know what they are doing. I have replaced heaps of pinion seals and not one crush tube. I also don't know how to set up a diff head correctly. A pinion seal is simple.
editted to add the smile
churchill
Did one in a Hiace van 10 years ago, didn't touch the crush tube and got close to another 200000kms out of it before we sold it. The reason why it was leaking was the breather was blocked as we found out for later, we cleaned it out and it never leaked again.
I think you need to remove the diff head as you'll need to set the bearing preload without the crownwheel in place. I don't see how you can use a torque wrench to crush the crush tube and accurately set the pinion bearing preloads unless there's something I'm missing.
sibainmud
All of this I told him in person too
The flange seal surface has a cut grove from the old seal (not that unusual to me) but he had the correct speedi sleave with him too, so it should be a half hour job
oldblue
Maybe there is something about this bearing that it needs to be changed for a new one?
sibainmud
Nup. Looked perfect to me and he said there were no issues with the bearings, he just wanted to replace the crush sleeve like the books say so.
The key to this is in his name and the fact he dwells on Lada's.
I have worked with a few of his country-men over the years and their belligerence amazes me (ask questions then argue your answers)
Definitely running the risk of no body helping out
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=22&t=26463
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=38&t=26462
Starting to know how you feel Wopass
Flash2004
You know? Everyone is right. i used to rebuild diffs for a living way back in another life before crush sleeves were invented. We used to spend hours on them using wet n dry to slowly peel off a few thou to get the pinion preload just exactly right, measuring it with a spring balance. Then we'd start setting up the R&P backlash with a dial gauge and a tube of marking blue for checking and adjusting pinion depth, side bearing preload and final tooth pattern. i mostly did Eaton truck diffs i must say, but quite a few valiant and other light Chrysler products as well.
The reasons were simple, minimum driveline lash for one thing, but primarily noise. there wasn't the insulation we have now and holdens were particularly bad at diff whine. Over tight truck diffs would glow in the dark as a worse case after a long trip so we had to get it right.
So how can we get away with reusing crush sleeves when all the experts say we can't? Mostly because most of you on here don't know any better which doesn't make you wrong. big mud tyres, noisy exhausts can hide diff whine and complaints, modern oils can hide a thousand sins and when you blow a diff, its because your wheels were too big and you gave it too much gas you think.
As well as that, i don't think anyone knows, or even needs to know how to set up a diff properly any more because generally if they're left alone they never fail.
lastly,my 80 series blew its rear diff seal at Christmas on the way to Pureora and oil was everywhere. That trip i used the Jeep so the cruiser just towed up and back. I clean forgot about it until WOF time and the thing had been running all that time virtually dry, but not a sound.
So I got one of the boys to change the seal. i got him to centre dot the end of the pinion and the corresponding part of the nut and count the turns as it came off. Then, after replacing the seal, i got him to wind the nut back on to exactly the same place and give it a gnat's cock more of a turn until I felt my own nuts tighten. the fill it up with oil and go get a WOF.
And it'll be fine. cheers, grandad.
sibainmud
While we are reminiscing,
I did my time doing stern legs on boats and we used the above methods too. I'm no stranger to backlash, preloads, tooth mesh and alikes.
Alex wanted to replace the crush sleeve because it said so and had no idea how much 1Nm of effort was (the value for preload).
He couldn't understand that to measure this or even estimate it the crown wheel needs to be removed.
He is trying to do a complete job in a half arsed way.
dr4lex
- Driver/Navigator
thanks, FITZY man,i wish yr post was the first and only answer to my question,saving me nerve and making it clear.
dr4lex
- Driver/Navigator
FITZY's like answer is what i expected from experienced crowd, not a pile of insults
mudlva
yeah no worries mate
next time you ask a question we will all leave it to somebody else to answer that way you get the answer that you want
Flash2004
dr4lex wrote:FITZY's like answer is what i expected from experienced crowd, not a pile of insults
I thought my answer was pretty good? No insults, took a lot of time, spells out exactly how to do it? Samatta witchu?
