1993 nissan safari diff
hi there ppl
Just wondering will a 1993 nissan safari diff fit under a 1988 nissan safari
thanks
thanks
It will, but it aint worth $1500.
Its also an air operated locker, not to be mistaken for an air locker. In other words its a factory locker.
He wants $1200 for a complete front diff, when others are selling them for under half that, with less km's on.
Everything he has listed so far is WAY over priced.
I think the reserve on that one was $1300 in a previous auction (which i think is also too much) you would be better off buying that and putting an LSD in the Rear if you dont have one already.
http://www.trademe.co.nz/Trade-Me-Motor ... 110525.htm
Re: ARB
try bruce hughes at hughes auto sevices, winton. they did have a special about $1750 incl compressor that was a while ago. i paid $2900 +gst for a pair front and rear with compressor, expensive but very good, the best part is you can switch them off.hogy_ wrote:how much will a new arb air lokka set me bak for a 1988 safari? and who would i contact to get one?
thanks
Re: ARB
hogy_ wrote:um i sorta have can u give me sum sites or ppl to ring on getting sum prices? for a auto lokka
The catch is there is only an Auto locker available for the front diff. Nothing available for the rear.
BUT, i approached a company over in OZ and for $1200 plus shipping etc etc they reckoned they could make me one.
Never followed it up any further, decided to stick with the LSD untill a factory one came along
Yeah the pinion bearing has got quite noisey, so rebuild time i will give it a go. Have "heard" from the skeptics that a tightened LSD doesn't stay tight for long.
Will see, depends what comes over from Japan for me
So far the LSD and the front auto locker work well enough
JTop wrote:Are you sure it's the pinion bearing, check the flange hasn't come loose.
How are your rear drive flange angles, do you need more G/B spacers
J Top
Yeah man, it's noisey between unloading and loading, and at anything over 110k's there's a wine aduiable over the road noise and exhaust.
Pinion bearing, but the rest probably need attention.
As for the drive shaft, yep its running some steep angles, but no worse than any other Safari with a lift. The UJ at the diff end has the shallower of the two angles and got adjustable upper radius arms to match it to the TCase end.
