V6 Petrol
For all Nissan related topics
mikee
V6 Petrol
Post by mikee »
Hi my mates V6 Terrano wont start seems to fire then floods.We have checked the ecu fault codes and get both red and green lights flashing at the same time 1 flash then 2 flashes then 3 flashes then 4 flashes then 5 both at the same time.There is nothing in his manual that relates to this.Any thoughts would be great,thanks mike.
slide
Re: V6 Petrol
Post by slide »
thats indicating the 5 diagnosis modes. u need to turn the screw thing back after the 3rd (I think????) flash, then it will start to flash the fault codes out
u13turbo
Re: V6 Petrol
Post by u13turbo »
Dont know if this will help, But i learnt if my sr20 floods you hold your foot hard on accelerator, and as you hear it starting to fire let your foot of slowly.
mikee
Re: V6 Petrol
Post by mikee »
Thanks Slide that worked :D :D
mikee
Re: V6 Petrol
Post by mikee »
Well that didn't work code 55 says no faults back to trawling the net for a obscure solution :roll:
slide
Re: V6 Petrol
Post by slide »
How long since new spark plugs have been fitted? If not recently, then try some new ones. I have personaly fixed a car that was driving along, died, and wouldnt restart. A new set of plugs and was away again! Worth a shot. Otherwise, maybe try a clamp on fuel line to trick it and lean it to get rid of flooding. It may fire up, then keep running if you release clamp at right time :wink:
mikee
Re: V6 Petrol
Post by mikee »
Yep done all that slide but still no go still checking things thou,cheers for the replys.
Return to “Nissan”
