1991 Terrano
u13turbo
Re: 1991 Terrano
Post by u13turbo »
Getting a camera next week so will start updating with pics!
So I've done a couple of little fix up sorting out jobs.
Got my torsion bar anchor out, Smashed it abit with a hammer to put it back into shape! worked OK and got then re indexed back up into the cross-member finally!
Also done as you said would be best KIWI_TERRANO, Spent a day at SIT last week cutting and welding my standard air-box, Got the 3" intake welded on, then went to something Fittings on annex road to get some 3" flexi pipe to hook it up with snorkel(No where in Rangiora had any... I tried, plumbing world, Mitre 10, Irrigation warehouse, Daiken heat pumps, and a couple of other places....)
Have noticed a difference, compared to the hot air it was sucking through a 2" hole, to now getting cold air through a 3" snorkel.
Gotta make up an oil catch can as its blowing alot through the intake... Also when i was doing torsions realized my right hand inner cv boot is cutties, just replaced the left hand one about 2 months ago.
KIWI_TERRANO
Re: 1991 Terrano
Post by KIWI_TERRANO »
Started saving fuel??
And ace have a big alloy bash plate for a terraon at the moe.
They pretty beefy might be worth a look
u13turbo
Re: 1991 Terrano
Post by u13turbo »
KIWI_TERRANO wrote:Started saving fuel??
I havnt noticed if im saving fuel yet, Costs me too much to fill it right up so cant really compare =/
I would like a good bash plate, but its really out of the budget atm... =/
I see your selling your surf, Coming back to a terrano?? haha
KIWI_TERRANO
Re: 1991 Terrano
na na need a hilux mate
u13turbo
Re: 1991 Terrano
Post by u13turbo »
Replaced inner CV boot, Found that my shock needs new bush, Were do i buy them from??
Finally bought a camera. Will be updating photos as soon as it arrives!
u13turbo
Re: 1991 Terrano
Post by u13turbo »
Ok heres an update, Finally got another camera!
New mount to put rope on, As you can see its bent a wee bit, will weld a brace on when i get a chance.
New idler arm, shorter than genuine nissan, had to pack out with washers for brace, Dont think it will be working all that well....
This shows the draglink hitting the chassis, This is on flat ground.... pretty bad really....
Engine bay, Can see big oil leaks around intake pipe from turb to inlet mani, Iv put a bottle as a catch can for abit to see if its coming from rocker cover or if seals in turbo are gone.
Snorkel all mounted, painted and plumbed up.
Bit of a scratch..
Amp mounted
Im looking at getting a cheap spotlight for the back, for night 4wding, Id just weld a bar to sit it back abit so the spare tyre doesnt block the light.
sibainmud
Re: 1991 Terrano
Post by sibainmud »
All that oil doesn't mean turbo seals are shot. When you run bigger boost, the air can't get through the air filter fast enough and it sucks from the crankcase breather which contains a heap of oil.
The place where it is coming from can be modified to seal it up to stop the boost pressure and the oil escaping.
Remove the butterfly assembly and plug holes with bolts or alike.
Also consider making/buying a breather dump can to help separate the oil from the crank case breather.
Here's the simple remedy for the shaft replacement.
u13turbo
Re: 1991 Terrano
Post by u13turbo »
Oh yes that looks easy enough to do! will do it on sunday hopefully I will have enough time off. Would that be why the other day i whipped the vacuum hose of the wastegate and was only getting a max of 12psi, and there was a very loud turbo whistle(im guessing leak)?
sibainmud
Re: 1991 Terrano
Post by sibainmud »
u13turbo wrote:Oh yes that looks easy enough to do! will do it on sunday hopefully I will have enough time off. Would that be why the other day i whipped the vacuum hose of the wastegate and was only getting a max of 12psi, and there was a very loud turbo whistle(im guessing leak)?
The loud whistle is from the hole where the breather went as I see you haven't blocked the nipple off at the S bend.
If you want to see if the induction system has any restrictions, take the "S" bend out and use a pod filter or similar for diagnosis purposes.
u13turbo
Re: 1991 Terrano
Post by u13turbo »
Oh na the loud whistle was from before i disconnected the breather and put into the bottle(also i did block the breather off, it has been taped up pretty well! i wouldnt leave is sucking in unfiltered air!)
sibainmud
Re: 1991 Terrano
Post by sibainmud »
My bad. couldn't see the tape :oops:
12 pound isn't much with no waste gate connected.
Either the turbo is on it's way out or there is a restriction somewhere.
Still disconnect the S bend and try (with some sort of filtration, as it is a dirty engine bay (just like mine :roll: ).
Or I'm thinking, when it was over fuelling you have chocked your muffler up. If you can, disconnect exhaust at first flange after the dump pipe, try that.
With standard exhaust, pod filter and no waste-gate it should be up around 16-18 psi.
Best of luck.
u13turbo
Re: 1991 Terrano
Post by u13turbo »
Sweet ill give this a shot on sunday! cheers Simon
fullthrottle
Shuttle Queen
Re: 1991 Terrano
Post by fullthrottle »
u13turbo wrote: Spent a day at SIT last week cutting and welding my standard air-box, Got the 3" intake welded on, then went to something Fittings on annex road to get some 3" flexi pipe to hook it up with snorkel(No where in Rangiora had any... I tried, plumbing world, Mitre 10, Irrigation warehouse, Daiken heat pumps, and a couple of other places....)
Hi, looking good.
I'm interested in the home made snorkel / air box mods. Do you have more pics of the airbox and snorkel setup?
Was thinking the same about making my own as I don't have 300 squid to blow on some platic pipe.
u13turbo
Re: 1991 Terrano
Post by u13turbo »
Hi, looking good.
Hey mate, My brother has my truck at the moment but im happy to get more pics of it when i next see it for you. I paid 180 for the snorkel itself, but you could make that part yourself aswell.
u13turbo
Re: 1991 Terrano
Post by u13turbo »
Starting to think its time i got my rated hooks on. For events etc, will the hooks be ok mounted on the bullbar bottom mount? and on the side of the towbar for rear?
TD power
Re: 1991 Terrano
Post by TD power »
have you wound the fuel up yet has it got smoke under full boost
u13turbo
Re: 1991 Terrano
Post by u13turbo »
TD power wrote:have you wound the fuel up yet has it got smoke under full boost
I had to wind it down, Im still running standard boost, Wanna get an EGT before i start playing with fuel, Just incase. Then it'll be all on :twisted:
TD power
Re: 1991 Terrano
Post by TD power »
get an intercooler on it to mate then wind it to 17psi
u13turbo
Re: 1991 Terrano
Post by u13turbo »
TD power wrote:get an intercooler on it to mate then wind it to 17psi
Could be a plan, I have a small front mount off my sr20det bluebird that i may beable to fit somehow. I'll measure up and see how it goes. Such a bastard, atm we run out of light at 5pm and i only have sundays off, not alot of time to get shit done.
Just bought 2x KL71 33's. Now what i need to know is, Will i definitly need a body lift to fit them? or with a lil bit of gaurd chop will it be allgood?
kiwipete
Re: 1991 Terrano
Post by kiwipete »
Idealy you need body and suspension lift. I have 2" body and 2.5" suspension lift with front guards trimmed near the doors and I still get rubbing. Rear guards will rub on articulation too but i cannot afford to get them trimmed ATM.
Ph 0212078472
DieselBoy
Re: 1991 Terrano
Post by DieselBoy »
Why do people always do this backwards the wrong way round and upside down????
Why would you dump more fuel into your engine with out giving it more air to burn it with??
That just creates heat, and clouds of black smoke that make your truck look like a shitter :lol: :lol: :lol:
Get your self a boost tap and tweak the boost up to were ever you want it to be or bypass the waste gate altogether, then increase your fueling but stop before it smokes at full boost.
Its that easy, and that simple :D :D :D
u13turbo
Re: 1991 Terrano
Post by u13turbo »
Ok, I have 2" suspension. Guess I'll need to get body aswel. One other thing, To guard chop, Can you just take to it with an angle grinder, and then tidy it up? does it come out alright?
Oh lol, I was not going to put more fuel in with the standard boost.... Im going to run 17psi as TDpower said, But i want an EGT gauge before upping fuel, And i need to up fuel to up boost. So before anything happens, i need an EGT :)
DieselBoy
Re: 1991 Terrano
Post by DieselBoy »
Urrrrrrrm, no, you don't need to up the fuel to up the boost on a diesel.
Like I said, fit a boost tap or just bypass the waste gate altogether.
Its simple. Pop the hose off the waste gate actuator, put a screw in the end of the hose and go for a drive. Hey presto, more boost.
After you have done that, then play with the fuel.
I'm guessing your experience is with Petrol engines in cars, were upping the boost with out upping the fuel to match leads to a leen mixture, heat and engine destruction??
Total opposite with a diesel.
You give then only the barest amount of fuel they need to make the boost and power you want.
Do the waste gate thing and report back what it boosts to!!!!!
u13turbo
Re: 1991 Terrano
Post by u13turbo »
DieselBoy wrote:Urrrrrrrm, no, you don't need to up the fuel to up the boost on a diesel.
Oh i see, So if i free boost it right now the worst that can happen is blown turbo, or not as much power as possible because it doesnt have enough fuel? but it wont melt anything?
I have whipped the wastegate pipe off, and it only made 13psi... Think its due to a boost leak cos i can hear a massive whistle, And it know were it is, look up the page and you'l see what Simon told me to do.
TD power
Re: 1991 Terrano
Post by TD power »
i was asking if it smokes under fullboost because it was only boosting 12psi with no wastegate
u13turbo
Re: 1991 Terrano
Post by u13turbo »
on way home from town early this morning my brakes got really hard, and lights started dimming, so i thought it must be alternater belt because of vaccuum pump also. When i got home i took a look and found that the oil filler had popped off, gushed oil everywhere and the alternater tensioner bolt had snapped off! Luckily there is still alot of oil in engine....
kiwipete
Re: 1991 Terrano
Post by kiwipete »
That was lucky you did not seize it. Time for a big steam clean now?
Ph 0212078472
Lynx
Re: 1991 Terrano
Post by Lynx »
You have to ask yourself, why did the cap pop off??
Cheers Daniel
u13turbo
Re: 1991 Terrano
Post by u13turbo »
kiwipete wrote:That was lucky you did not seize it. Time for a big steam clean now?
I no! As soon as i opened the bonnet i thought, "oh shit..." But i checked oil level and it was half way up dipstick. And yeah hopefully I might beable at work ex tomorrow.
Lynx wrote:You have to ask yourself, why did the cap pop off??
Cheers Daniel
Because my brothers mate didnt tighten it up enough.... :roll:
radar21
Re: 1991 Terrano
Post by radar21 »
at my work we have a couple of homy vans that the filler cap come lose by them selves the threads on them get worn then as the engines vibrate the just work them selves lose
scott gibson
