have 80 series springs for front supposed to lift 2-3 inch ???
what fits the rear to give the same lift ?????
info on truck is y60 highroof lwb
forgot to mention CHEAP please thanks in advance.........
taz01
lifting GQ help ?
lifting GQ help ?
WARNING:
- crazyclark31
Re: lifting GQ help ?
from what i know you'd just have to get some safari ones. Know the guys at cobra springs do good deals.Most people put standard safari springs in other trucks(pajero's) for lift.
My shorty with pto winch lifted bout 65mm when put them in mine. Was slightly low in the back with 60mm lift rears and normal 4wd gear in boot
mike barnett
if doing a 3" lift in the front i would be doing a 4" lift in the back for a lwb, by the time you have loaded the boot with gear etc or towing it will sit flat,they also dont take long to ....well sag a bit so a we bit more is good.imo.
