aisin carb air/fuel question
what way do i turn the screw to richen the mixture?
- tomsoffroad
- Flopsie
Re: aisin carb air/fuel question
Usually you wind them out to richen.
cool can anyone confirm this. aisin 8300 carb
can anyone confirm??????
- Sadam_Husain
- Angry bird
it'll only adjust the idle mixture, you'll have to change the main jets to adjust the carb mixture. Generaly you wind the idle mixture screw out to richen then start winding back in to lean it back up untill it idles right just before it starts to falter a bit
