toyota 5m-ge engine
toyota 5m-ge engine
hi all have just finished a supra to surf swap and SAS and rear spring swap but for some reason the engine has thrown a wobbly and now runs like a pice of shit so i need a complete engine manual . and i know what you all are going to say but the toyota dealer in timaru do not have this manual so can any one help with sourcing a manual thanks .
hi
no Toyota runs like shit they just have good and bad days.Workshop manuals are hard to come by it sounds like you may have done something wrong on installation................soooooo tell the group your problems and im sure some one will get it right. Not much can go wrong unlike some other breeds
and this is a common swap
hi
- tomsoffroad
- Flopsie
that would be good steve as the problem i am having is the engine is constantly running rich (and yes the cold start is off ) so a manual should get the problem sorted i hope this is very embarissing having to ask for help as i am a diesel machinc but have never worked on any petrol engines so dont quite understand air flow meters as i think this is where the problem may be so my address is 4 matai st pleasant point ( just 10 mins out of timaru ) ph 03-6148727 thanks . ps what do you drink !
You don't have a crook temp sensor (the little things with wires on em on the top front of the motor) do you? I seem to recall they could cause that or something similar - Mikes the man to ask about that.
The other thing I did
was put my airflow meter in back-to-front - that made it run like shit
Don't s'pose its something stupid like that?
Anyway I'll send it away in the next couple of days - Speights is my poison - next time you are in Chch buy us one each and we'll be square
Steve
Steve
oh-gee-dah the AFM is fitted correctly and yes all the sensors are sending the correct signal (IE resistance) to the ECM . and DJ have checked the cold start injector and have also removed it from the enging and pluged all orifice's so pleace keep all the questions coming as am dying to go and have a play ...
- tomsoffroad
- Flopsie
- tomsoffroad
- Flopsie
hmm spark plug been there done that also checked fuel rail pressure + engine compression and all is with in spec ( talked to suprsurf and have brought purchased a ECM to try . but this you make you all sick as i won lotto on saturday and hmmmm what to do .. as it was a very large amount . but hi ho hi ho its off to the big toy shop i go hehehe
- tomsoffroad
- Flopsie
- tomsoffroad
- Flopsie
- tomsoffroad
- Flopsie
Cough cough.... I know what you did wrong Lloyd!!!! cough cough!!!!!
[b]a man who wins Lotto can do no wrong [/b]
now as a I have buttered you up. As I have paid into Lotto for years and won sweet F.A. I feel that I should have a small donation as, after all thats a chunk of my money you have. Hummer H2,s are on special and Xmass is just around the corner
seriuosly GOOD ON YA that man deserves a beer
oh well its worth a crack
- tomsoffroad
- Flopsie
hi all you peasants (joke)
as for the win yippee but will as i am a young dude i will probably invest most of it as NZ is getting to be an old pouulation (sorry old dudes but it true ) and i will not be working as an old man as for the f##king surf it is still running like a pice of shit . fitted a new ECM tonight +new dizz + new spark plugs and leads + new coolant temp sender and gess what #### ALL difference (might just buy a 7M - GE himmmmmmmm but time will tell . cheers pinky
- tomsoffroad
- Flopsie
well pulled the engine down tonight and here is what happend No 6 conrod broke away from the piston and proceeded to snap the crankshaft and i dont know how but the conrod ended up half way through the cylinder head and what was left of the piston is now in the sump as shrapnal so yes it is all doom & gloom
If you want I can help you out with a block I've still got the spare one here... just got a small crack above the oil pump drive shaft, from when teh last owner dropped #1, easy fixed
don't buy another lotto ticket looks like you've used all your good luck up
If you'd like the block its yours just pay the frieght
Cheers Reece
Cheers Reece
De Ranged Engineering
027 541 8794
027 541 8794
