Alarms
rob-mu
Alarms
Post by rob-mu »
As my truck is starting to look like worth stealing I want to get a alarm asap.As I plan to do a bit of remote 4wding I dont want to have to worry about flat batterys etc.Is there anything I should be looking at getting done to prevent this?
Any models I should be looking at?I want one that has a built in turbo timer
Rob
Re: Alarms
Dynatron are good, got an AVS one this time but this is a pos one
rob-mu
Re: Alarms
Post by rob-mu »
rangimotors
Re: Alarms
Post by rangimotors »
if your not going to put it in your self make sure your learn how its wired and know how to by-pass it. Keep a cheap pair of cutters and some crimps/chocky block/tape in ya glove box. Not good when your miles from anywhere and you drown your alarm and can't start ya truck.
Thats mongoose one looks like a good price
rob-mu
Re: Alarms
Post by rob-mu »
Cheers dave,Was just going to ask about drowning the thing
Rob
rangimotors
Re: Alarms
they are usually pretty good if the control box is tucked right up under the dash instead of in the engine bay. The ones i have seen give problems are the ones that "arm" themselves (you know the ones that everytime you turn ya rig off you have to push the alram before you start it again) its better to get one that only arms when you want it to and then you obviously never arm it offroad when your trucks just popped out of a river and stalled
mud_slinger
Re: Alarms
Post by mud_slinger »
chuck a kill switch in it then if goes underwater no dramas otherwise you'll be stuggling with lots of spaghetti to try to find out why it died in a deep river and immobilised. are alarms even waterproof?
jus get one of these
[imgImage][/img]
[imgImage][/img]
problem solved :lol:
needs more curry
0272593533
tweake
Re: Alarms
Post by tweake »
alarms only disable an engine one or two ways. very easy to bypass if you know where to look. so you may need something a bit more like fuel cutoff etc.
if its got an ECU you can do a few more things.
mud_slinger
Re: Alarms
his is mehanical pump
needs more curry
0272593533
tweake
Re: Alarms
Post by tweake »
mud_slinger wrote:his is mehanical pump
that makes it difficult as they are easy to get going. great for the bush, lousy to stop someone else getting it going.
i have heard of putting a fuel valve in with cable running into cab for on/off. one nice one is electric fence unit wired into the seats.
you don't want to forget to turn it off before sitting down ;)
or an exhaust brake or inlet butterfly with hidden switch.
if you have valuables inside need to get an alarm that has an internal sensor. otherwise they just remove the windows and grab all the gear.
BigRedCruiser
Re: Alarms
Post by BigRedCruiser »
get the lion dog i wuldnt jump in a car with that! that thing wuld kill a man ! love the electric fence seat idea too. just have sum very small hidden warning on the inside of the truck so when the crim sues you for hurting him while hes ripping ur car off uv gt a warning sign. gotta love NZ :oops:
juz
Re: Alarms
Post by juz »
Not much help with alarms sorry but found this on Tardme today, jesus theyll take anything aye! :evil: Think Ill throw a Kill switch in my truck now too..
http://www.trademe.co.nz/motors/used-cars/nissan/auction-395411564.htm
Return to “Tool Shed”
