Dyneema Winch Rope on Nissan PTO
Hi
Have a mate who is looking at putting 10mm Dyneema Winch Rope on his PTO winch and wants to know how much he can fit on the drum before he will run into problems??
This is the stuff he is looking at getting
http://www.trademe.co.nz/motors/car-par ... 714972.htm
Cheers in advance
Cheers in advance
Team Lada Loves Sloppy Holes!!!!!!!!!!!!!!!
Re: Dyneema Winch Rope on Nissan PTO
Yeah, someone just bid against Kiwipete
I bet he's happy.
All good.
I bet he's happy.
All good.
- Sadam_Husain
- Angry bird
yeah that will fit fine, I've got a nissan pto winch on my 40 series with 35m of 10mm synthetic rope on the drum
Yeah what sadam said, I have a nissan pto on my 70 with that exact rope on it, could have fitted another 10m easy. Good rope so far...
sibainmud wrote:Yeah, someone just bid against Kiwipete![]()
I bet he's happy.
All good.
Gutted even
Ph 0212078472
Ph 0212078472
- Sadam_Husain
- Angry bird
email or ring him if you want one of his ropes
http://www.winch.co.nz/
Sadam_Husain wrote:email or ring him if you want one of his ropes
Emailing him is like watching paint dry, he takes ages to reply..........................
Speaking from personal experience here.
Ph 0212078472
Ph 0212078472
Sadam_Husain wrote:yeah that will fit fine, I've got a nissan pto winch on my 40 series with 35m of 10mm synthetic rope on the drum
Cheers, much room left on the drum?? Go to 40m??
mayday wrote:Yeah what sadam said, I have a nissan pto on my 70 with that exact rope on it, could have fitted another 10m easy. Good rope so far...
Cheers how much more you think??
I have 40 meters on mine and prob get another 10 on there without any trouble
SirGerald wrote:Sadam_Husain wrote:yeah that will fit fine, I've got a nissan pto winch on my 40 series with 35m of 10mm synthetic rope on the drum
Cheers, much room left on the drum?? Go to 40m??mayday wrote:Yeah what sadam said, I have a nissan pto on my 70 with that exact rope on it, could have fitted another 10m easy. Good rope so far...
I'm still using wire, but I recomend that you don't fill drum completely. Your rearly (if ever) winching straight ahead to enable you to wind rope on evenly. It always seems to be overfill on one side, and only a little on other side. If you want length, buy an extra piece as an extension.
I could have fitted another 10m with enough room left for bunching up when winching easy
Check eBay, at the moment they have 10mm X 30M at $1 reserve. I'm winning an auction for $50 Aussie. Including $40 postage, it is still a great price at $120....
- Sadam_Husain
- Angry bird
Like Jeremey says you dont want too much rope on the drum or you end up with too much side bunching and the nissan drums are knowen to break the sides off when they get too much overloading, also your best pulling is down in the lower layers on the winch. You need to get a few bits of old broken winch rope to make up into various extn lengths when you need longer winching, I think I've got a 5m, 10m, 17m and 30m which is my next winch rope when my current one breaks, the eyes are easy to loop onto the bits of rope
35m of 10mm on a standard nissan drum, you wouldnt want to fill your drum up any more than that
on my list, a steel oversized drum like monsta's one
The other thing to think about is the factory drum has a habit of blowing the side out when over filled with rope. Synthetic rope flatens under load which creates massive side loads that the ali drum don't handle well. Less than 40m seems to be right but any more will see a higher risk of breaking the drum.
But yes you can fit more if you want!
had a good look at my spare drum, its a major engineering job to reproduce it in steel so not rushing in to build one
yzsglcn wrote:i got 40m 10mm dyneema winch rope at price 220US dollars
CHEERS TOO
Good price, what was freight?
I purchased 30mtrs 10mm Dyneema sk75 with eyelets in place for NZ$225.....can pay to look local too
