Have been looking around the site for a while and thought I would introduce myself and ask for some advice.
I am only 4wd with mates socially at this stage
I currently have a Terrano (which is on trade me) has 33" Simex'es, no roof, just roll caged, winch, welded rear diff, fiddle brakes for front wheels, body lift etc. goes really well off road but is getting a bit light to keep up with everyone elses Safari's so started on the new project about three weeks ago.
It started like this
Now it looks like this
I have gotten a front wheel on it now (buying them 1 a month)
The back wheel is turned not broken, It's gunna be off road only so we are gunna make it four wheel steer for something a bit different.
I have taken photo's as we have done everything so if anyone is interested I'm happy to post them if you let me know where is most appropriate.
Anyway I am after some thoughts on the front axle set up, the two swing arms going back to the chassis seem like a bit of a weak point and as the body and suspension are to be lifted I need to do something with them anyway.
My Thoughts are to cut some 30mm ish plate with a similar shape to the swing arms but with a drop in it and change the rear mount to a bush which would make the arm much stronger and save building drop boxes
Or,
Maybe look at welding brackets to the diff and make it a four link front end this would be more work but I guess there must be some pay back performance wise?
Can any body tell me what the handling and offroad capabiltiy difference between the two options would be? or if there is a better option?
Thanks in advance for any help
Dayne
