anyone know what these winches are like?
http://www.trademe.co.nz/motors/car-par ... 267460.htm.
Seem to come with all the right bits but am are unsure on the quality
Xdyna winch
- crazyclark31
Re: Xdyna winch
Cant be much different to the runva ones, price seems pretty good too
Didn't barbie drive a jeep??
- crazyclark31
Re: Xdyna winch
yeh thats why i'm looking. not sure on the electric freespool though. Would be hoping that it would still work when nose is buried on a swamp runner when doing comp soon. Esp when its 2am!!. Gota love 24hr challenges
Re: Xdyna winch
Use it with the battery cable supplied and you will fry the motor. It is 25mm which is good for about 250amps only. The cable needs to be upgraded to at least 50mm but really 70mm is minimum if you have a 6hp motor version. I always use 95mm for competition winches but that is about duration of winching and not getting any heat build up.
Re: Xdyna winch
pjb wrote:These look identical to the tigerz11 winches.
You mean peal the stickers of Tigerz11 and you will find Xdyna underneath!
- crazyclark31
Re: Xdyna winch
darinz wrote:pjb wrote:These look identical to the tigerz11 winches.
yep that they are. Do know that they are pulled down and have far better seals fitted and have the electric free spool taken off and a manual level put on. The electric f/spool isn't sealed so no good in water.
Due to cost restrants i've gone for the 12000lb runva.
