I got a lj80 with a 4k corolla motor in it .When i charge up a steep hill or hit a bump to hard the motor seems to flood.Is there any modification I can do to the carby to fix this.
lj 80 with 4k toyota
Im wondering if anyone can help me with a carberator problem im having?
Re: lj 80 with 4k toyota
hey m8 ,my advice would b,get ur float bowl pickup modified,c if u can get what you call whistlers that fit into the float bowl, i know they make em for holleys!,or if no joy there id be making a surge tank and that will solve all ur probs,my m8 years ago had a zuk with a 1500 datto in it and we fitted a surge tank to it and a 2nd fuel pump and then the zuk would idle all day long on any angle or steep climb,i hope this will give you some positive results,cheerswocky wrote:Im wondering if anyone can help me with a carberator problem im having?
I got a lj80 with a 4k corolla motor in it .When i charge up a steep hill or hit a bump to hard the motor seems to flood.Is there any modification I c an do to the carby to fix this.
hi DJ the suzi is 1980 with leaf springs,single cab with 4k engine & 32 inch tyres .a neat wee toy
& light to tow.
thanks for the advise TOYKING.What are whistler & were would you get them.
