1KZTE Buying tips
1KZTE Buying tips
As above, Am buying a 1kzte surf. Any tips would be great, Things to look for and common problems?
Cheers guys
Cheers guys
Re: 1KZTE Buying tips
cooling system is a must , there is an old thread on here somewhere that has all this in detail but like usual ya gotta search for it. have a good look and it will turn up
DIRTY OLD HILUX
022 519 7700
022 519 7700
Yeah ive heard a wee bit , I did search man the forum aswell as google. May have worded it wrong though,
search on google 1kz te faults
comes up with shitloads
DIRTY OLD HILUX
022 519 7700
022 519 7700
Ok cheers mate
look for Toyota factory service stickers on drivers side door jam.
look for one that has done the majority of its kms on the open road , not around town .
LR110 ..... LJ50 project
Ok thanks mate,
Got one lined up for today so will check it out, My biggest fare is the cooling system.
- KIWI_TERRANO
get a compression test done, they are really good at doing heads round the 200000km mark in the kzn130 the later model kzn185 are a bit better.
check for rust in front doors and just in front of rear flares
Yeh its a kzn130.
Done just over 270 ks. New head has been fitted along with water pump etc aprantaly!
- KIWI_TERRANO
in that case the head problem should be solved.
as long as it wasnt a cheap nock off head instead of a toyota one
skux , the cooling system in any vehicle is important but what is more important is monitoring the internal combustion heat via an exhaust gas temperature gauge, do an EGT or PYRO GAUGE search, it has been well documented. Once monitored you need to change your driving style to keep your EGT below 650deg C. I believe that this is what will give you longevity out of any engine.
KEEP COOL,
FITZY.
KEEP COOL,
FITZY.
SMOKEY wrote:skux , the cooling system in any vehicle is important but what is more important is monitoring the internal combustion heat via an exhaust gas temperature gauge, do an EGT or PYRO GAUGE search, it has been well documented. Once monitored you need to change your driving style to keep your EGT below 650deg C. I believe that this is what will give you longevity out of any engine.
KEEP COOL,
FITZY.
Yeh cheer's mate ive read abit now thanks to couple links from "chrome".
1st thing on the list will be getting a dump pipe made, Then ill do exhaust from there on. Also i have a intercooler already & A water temp gauge!
KEEP COOL,
FITZY.
good advice here, you dont know what you cant see aye...
DIRTY OLD HILUX
022 519 7700
022 519 7700
Giday, is that the short wheel base prado sx in Fairlie? I got a mechanic to look over it and do a compression tests here if u want them. They look good. Not keen on the truck anymore
vinceparts
im selling one with head done, water temp guage done , thermostat done, viscous fan fluid done, auto trans cooler done, intercooler done, and 3 inch dump pipe and exhaust doen, it may be what youre after and save u alot of money doing it all yourself
http://www.trademe.co.nz/Browse/Listing ... =399554537
the other thing to check is how well the drive train has been greased - no grease, doesn't matter what the oil like, it hasn't been serviced properly
happy hunting - maurice
Maurice
KZN185, 1KZTE running needing birthday
