a rock lobster or 4.16 gear ser is made from cutting and welding half 413,half 410 counter gear together. and then mix and match some gears .
. machining of the hardened gear is expensive ,due to cutting head use .
But you have the hard part find , the 84 410 transfercase, so proborbly a bit cheaper than imported gears.
lower gearing for sj410b
Re: lower gearing for sj410b
LR110 ..... LJ50 project
Or you could sell your current transfer case as they are quite desirable (I'm looking for one) and buy some transfer gears from the US. This would give you a greater range of gearing options to choose from depending on what size your tyres are.
suzookyman
If you decide to do the rocklobster I have a 413 case here that I need
to sell to fund other things just pm me if you want it.
suzookyman
zukmeista wrote:Or you could sell your current transfer case as they are quite desirable (I'm looking for one) and buy some transfer gears from the US. This would give you a greater range of gearing options to choose from depending on what size your tyres are.
They are around, one just sold recently on T/ME for $90.
Not with a light switch though
suzookyman
zukmeista wrote:Not with a light switch though
yes it did, haha your loss. (oh and iv got one and no you can't have it! )
where abouts are you located ?
Any decent engineering shop should be able to machine and tig weld the gear together.
