electrical help please WD21
For all Nissan related topics
keithal
Post by keithal »
i have installed an aftermarket sterio into my terrano and since then the fuse for the dash lights and tail lights?? keeps blowing. any idea what the problem could be?
thanks in advance
DKZ
Re: electrical help please WD21
Post by DKZ »
Double-check your wiring behind your new stereo, you may have connected the wrong wires together i.e. 12V+ to ACC on headunit or vice versa.
To help with problems like this in future you can buy a harness adaptor from Repco or SuperCheap for $15 or so, just get the correct ones, plug them in and you're away laughing :)
Currently driving: 2000 Nissan 200SX. and 1988 Nissan Safari
A bullet may have your name on it but shrapnel is addressed "To Whom It May Concern,"
keithal
Post by keithal »
DKZ wrote:Double-check your wiring behind your new stereo, you may have connected the wrong wires together i.e. 12V+ to ACC on headunit or vice versa.yup have checked that all wiring is correct
To help with problems like this in future you can buy a harness adaptor from Repco or SuperCheap for $15 or so, just get the correct ones, plug them in and you're away laughing :)i would have but the factory stereo loom had already been cut by previous owner
DKZ
Post by DKZ »
Check all the wiring, make sure there aren't any shorts anywhere.
slide
Post by slide »
You've connected the earth wire from stereo to the park light wire.
Disconnect the earth from the stereo, and connect up to a nice bit of steel in behind the stereo.
Insulate up the other (park) wire, and you'll be sorted.
I've seen (and fixed) this problem numerous times where people have done that.
Easy As 8)
keithal
Post by keithal »
slide wrote:You've connected the earth wire from stereo to the park light wire.
Easy As 8)
ok will give it a go thanks
rangimotors
Post by rangimotors »
Easy As 8)
x2 easy mistake to make, you check the wire with a test light or multimeter to confirm theres no power on it but the power only comes on when you have ya lights on.
keithal
Post by keithal »
yep sorted now thanks guys
kiwipete
Post by kiwipete »
keithal wrote:yep sorted now thanks guys
What was the issue in the end?
Ph 0212078472
keithal
Post by keithal »
mate who wired in head unit wired earth in wrong place
turns out its quite common as another mate had this same problem in his proceed
Return to “Nissan”
