i was going for an exo but i would then have to build a cargo barrier and mounting points for harnesses. So i am going to try and kill 2 birds with one stone.
Up untill a few weeks ago i also though i would have a problem with head room, but have since removed the head lining and gained 30mm of head room. I am also making new seat mounts for my buckets that are 30mm lower (was sitting up too high)
GQTROL: When you say twin lug construction for the main hoop, do you mean: the main hoop bolts through the body to another peice of plate that is attached to the chassis via another small peice of tube and a plate? Like in this photo?
If not, could you please enlighten my primitive mind on what a twin lug construction is?
