Strong IFS
Strong IFS
From experience, whats the strongest IFS system readily available today? Something that could take 35's on the original steering, knuckles, bearings and cv's?
Re: Strong IFS
Pajeros? other than that I am out of sugestions
Lubrication Specialist
Lubrication Engineers
Re: Strong IFS
Yup, specifically the Mk II's, handle the bigger wheels easy.
Re: Strong IFS
Ah of course, Pajero. After seeing the Prado ones drop the ball joints and I wasn't keen to use them. So no front driveline problems with Pajero's?
Re: Strong IFS
as far as I know, not really. Ours have never had problems. Others with more modified ones might know other wise though
- mudlva
Re: Strong IFS
dont alter the bump stops had a mate who bought a truck with the bump stops removed and was always breaking cvs the got an old truck for parts and noticed the missing bits installed them into his truck and cvs stoped breaking something about the wheel traveling past the cv geometry or something like that any way he trashed it hard for a good year or more and they were still going good as
he then pulled the whole front end out and installed a solid axle
Re: Strong IFS
Cheers Lincoon.
Mudlva, that makes sense, I suspect he was bottoming out the cv's.
Re: Strong IFS
Front ends are awesome, trimmed bump stops + ball joint flip + front locker + 33's + heavy chains = never damaged a thing. Some have bend steering idlers, some have done a CV but thats getting fairly brutal.
I bent the splines in the steering box and shore the teeth off the rear diff locker but the front end is still all good.
Re: Strong IFS
Wicked, thanks NVJ6.
Re: Strong IFS
had a 92 running 35's. I fliped top ball joint and used a spacer to reduce having to crank torsion bars but still had outter cv's problems, also had a 50mm body lift to help clear 35's but if i was to do it again i would just do a bigger body lift and keep torsions near factory height.
Re: Strong IFS
I dont know about others but I have never had any issues with my front end and I have been driving it pretty hard lately. But thats only on 32inch wheels and 3inch lift, ball joint flip.
Re: Strong IFS
madlux wrote:had a 92 running 35's. I fliped top ball joint and used a spacer to reduce having to crank torsion bars but still had outter cv's problems, also had a 50mm body lift to help clear 35's but if i was to do it again i would just do a bigger body lift and keep torsions near factory height.
That is a nice truck.
Yeah apart from my C.V's that click, I have had no majour Issues from the front on my truck.
Re: Strong IFS
Madlux, so you had a suspension lift? If so, how much? What was happening to your CV's?
Forge, don't lie, you've always driven it hard.
Drurban, what size tyres are you running and what year is you Mu?
NJV6, thanks.
NJV6, thanks.
Re: Strong IFS
Drurban, just read your signature and it says 33". Need to read more before I type...
Re: Strong IFS
Why not just go beam axle? to costly?
- mud_slinger
Re: Strong IFS
mu front ends are strong i run 34's and haven't had issues, just keep buyin worn 2nd hand cv's thats the only issue (dont know they are stuffed til i hit 4wd and start clicking so i jus use em til they break)
needs more curry
0272593533
0272593533
Re: Strong IFS
mud_slinger wrote:mu front ends are strong i run 34's and haven't had issues, just keep buyin worn 2nd hand cv's thats the only issue (dont know they are stuffed til i hit 4wd and start clicking so i jus use em til they break)
That is what I have ended up doing I just drive until something breaks.
- mud_slinger
Re: Strong IFS
i buy 2nd hand factory cv's strong as hell wen they aint farked lol. my old mu ran for 4 years with 34's never broke a cv and that was some rough treatment
needs more curry
0272593533
0272593533
Re: Strong IFS
One of our club members breaks a CV (on a Mu) almost every trip without fail!!!!
Front locka. Shatters the housings, got rings put around them to stop that then it broke the axles at the spline!!
Re: Strong IFS
u13turbo wrote:Why not just go beam axle? to costly?
I'm trying to design a new "Hybrid" suspension to give the best aspects of both suspension types and need to find the right parts to make it from.
- mud_slinger
Re: Strong IFS
NJV6 wrote:One of our club members breaks a CV (on a Mu) almost every trip without fail!!!!
must be a rough driver. if he ran factory ones and not cheap knock offs he'll be sweet, his best bet be to find 2nd hand factory ones as they about same price as knock offs and are alot stronger. my front locker broke a knock off in less than 5 mins and that was climbing a small incline
needs more curry
0272593533
0272593533
- crazyclark31
Re: Strong IFS
mud_slinger wrote:NJV6 wrote:One of our club members breaks a CV (on a Mu) almost every trip without fail!!!!
No a guy whose got a mu and he's forever breaking cv's. Has tried every type out there minus cromolly ones. has a Front lockka as well.
Have watched a guy doing hard hill climb in a pajero. Had 33s with chains on,got air under fronts,come down with power on and didn't break a thing!! Blew me away
Re: Strong IFS
It'll be the same black LilMu we are talking about Mike...???
Chains are awesome
Chains are awesome
- crazyclark31
Re: Strong IFS
NJV6 wrote:It'll be the same black LilMu we are talking about Mike...???
Chains are awesome
Yeh man. Was at wiakawa hile back and he blew a cv dropping sideways into a rut.
Yeh reckon chains are the shizz to.(used correctly)
Re: Strong IFS
churchill - lift was about 50-60mm. Cv's Kept crapping out and clicking.
Re: Strong IFS
madlux wrote:churchill - lift was about 50-60mm. Cv's Kept crapping out and clicking.
Interesting, thats not that big.
Re: Strong IFS
Hey Churchill,
I've got 50 mm lift up front, with ball joint flip and spacers, and trimmed bump stops, 33s. Been running that set up for about 5 years without a problem.
Only problem I've got is the steering can't cope with the increased scrub radius (offset rims) when the front locker is in. If one wheel starts wanting to drive up the bank, it is impossible to steer it out. That said, have never done a tie-rod or anything...
94 Pajero SWB, 3.5 V6
Re: Strong IFS
pjb wrote:Hey Churchill,
Hey man. Interesting, I've been thinking about that and I'll definatly try and get the axis to the centre of the contact patch. Might mean using low offset wheels and bringing the top ball joint out above the wheel.
Re: Strong IFS
Bighorns use quite big positive offset rims, something like +18 or something. Upside is the a-arms extend further into the wheel, which means they are longer and get more travel. Downside is the free-wheeling hubs hang out in the breeze somewhat.
Re: Strong IFS
churchill wrote:u13turbo wrote:Why not just go beam axle? to costly?
That is going to be heavy? And to be frank will probably end up with the worse of both worlds.
Try searching for 'twin traction beam'and you'll find what is probably the best way of doing it and that was a factory option on alot of Ford Explorers and Ranger úp untill the early 90's.
If you want strong IFS then most are using Chevy uprights and CV's but if you are really serious then about US$15k will buy you an unbreakable (ish) IFS that will handle big hp and 42's.
Also Paj CV's are bigger than GQ Safari ones but the axles are smaller.
