wireing map for mu
For all Isuzu related topics
ant-neil
wireing map for mu
Post by ant-neil »
the wires under my seat im thinking they do something they have been unplugged and doesnt seem to do anything different but some go under centre console thinking they just for 4wd dash lights . it a auto
to many wires and to much water
Drurban
Re: wireing map for mu
Post by Drurban »
ant-neil wrote:the wires under my seat im thinking they do something they have been unplugged and doesnt seem to do anything different but some go under centre console thinking they just for 4wd dash lights . it a auto
Those under the seat would be for the seat warmer at a guess, Iam not too familar with Auto's as I have a manual.
Cheers.
Suza
Post by Suza »
They are there for the seat warmer and any other factorie extras that could have been added
ant-neil
Post by ant-neil »
theres one plugged in the the floor thats stumps me
the one that go under the seat are the controls for the passsenger side windows
it goes straight threw and into aposite apiller
i want to bob tail the back and wondering the easyest way to disconect tail light wires
picking a fuse is enough but thinking if i dont want headlights what is left in the fuse box i need ???
not fussed about dash either
is it hard to wire these diesels
starter, fuel pump, alternator and kill switch
and can i run a tank on back like where back seat is ???
if its higher i dont think i need a fuel pump
any help would be awesome
im trying club isuzu also
dazza85
Post by dazza85 »
If its a diesel it does not have a separate fuel pump, its part of the injector pump, on the earlier Isuzu's the wiring for the tail-end comes out underneath the body in-front of the fuel tank and travels along the chassis to the back right corner and then across the body to the left corner like most modern vehicles they have an engine control computer that controls fuel cutoff glow plugs etc these ace commonly located in the side kick panels - you could just pull the fuses for all the stuff that you don't want, that should work fine.
ant-neil
Post by ant-neil »
is the auto wired to the brakes
the wire that plugs into the floor goes to the front brakes
i thinking that when you brake the auto disengages
I THINK
An auto electrician may have to be contacted before i pull anymore wires
or just cut the lot and get basics rewired
hit and hope maybe haha
george.ene
Post by george.ene »
It it is the loom you will find its the passenger side window, central locking, some illumination and a few others.
My Auto/DIY Blog:
http://www.georgeene.com
Return to “Isuzu”
