Hi
Looking at buying this and putting this in my 1993 Vitara. I have 31" Super Swampers. The engine has been worked currently goes really well but want to put some more height in to it.
Does any one have any feedback on this? Not sure if this is the right way or just put some EFS springs and shocks in with a 25mm lfit?
Any comments would be great.
Thanks
Dave
CALMINI 3" SUPER ARTICULATION SYSTEM
- suzukisport
Re: CALMINI 3" SUPER ARTICULATION SYSTEM
Have a read of this
http://www.offroadexpress.co.nz/Forums/ ... 23&t=25955
HI Suzukisport
Thanks for this.
Yep so the EFS will be the way I go.
Dave
Thanks for this.
Dave
griffsta88
- Winch master
hey m8 i have one, thay are verry good for some points, but not so good in others i have the calmini 3+3 lift, it needs a lil tweaks to get it right but think after i am finished it will handle verry well, i got the kit witout front struts (gunna get ome or iron man ) much better as have increased travel unlike calminis witch are a cheeper version of factory all up they are good, springs stiff in the front but think over time will relax and helps for less body roll on road
You can get 50mm lift springs from Cobra springs for $400.
