Shock absorber crush tubes
Can anyone point me in the right direction?...I'm in need of 8 crush tubes..12mm ID, 19mm OD, 40mm long.
suzookyman
Re: Shock absorber crush tubes
Have you tried Bay Engineering Supplies or Donvans?
Just get someone to make them for you. My dad is an engineer and I could get him to make some if you want
surely steel and tube will sell you length. a length of tube costs around 50 bucks so crush tube wont cost much.
- mudlva
i have used 1/2 inch galv water pipe
grind the galv off and away i went
theses will be crush tube for the steering box
the LC o.e stuff would of been lucky to be 1.5mm thick sidewalls and not overly hightensile as i had to drill the old one out and once thru the weld they drilled quite easy
jmt
jmt
