Basically the proceedure they should have followed was
Bleed the system "properly" (as I aked not how they did).
Check the radiator cap (pressure and vacuum)
give the vehicle a week with the system cleared and maybe a new cap.
if symptoms persist
Pressure test the system
Check for presurisation of the cooling system while running
check for presence of combustion gasses
If the first two had been done maybe I would not be out of pocket. if the last three proved to be bad news then "off with its head".
Unfortunately they weren't so the work was done purely on the evidence of bubbles in the radiator when running. There may have been some presurising of the system but it was not 100% apparent and was never checked.
Lessons to be taken from this is do the basics first, cross off all the simple fixes (10 dollar cap vs 3 grand for a head) before going for the biggies. Be confident with the "professionals" and tell them what you want done and dont settle for less - you are paying after all and the customer is always right until proven wrong. Get them to explain their reasoning behind their ideas.
Now I have to prove the head was fine (the gasket was fine) and the work done was unnessesary which will cost me extra $$$. Of course I am happy to pay for the head (it is fitted after all) but maybe the labour is too much. I will sell the old head if its okay to offset the costs - If its okay. If it isnt then this is all just a waste of time and the work done was justified. Just not approached in the way it should have been and they/I got lucky.
