white smoke
dave gone jeepy
white smoke
Post by dave gone jeepy »
Its an old mitsi 2.7 non turbo diesel 4dr5 vintage 1980, when starting lots and I mean lots of white smoke out the back but only when cold, runs great when going.
I replaced the glow plugs pre quake in june lol, am guessing and thats risky, it's the fuel pump maybe out of ajustment ? or is it worse like re kitting seals etc.
sibainmud
Re: white smoke
Post by sibainmud »
20 seconds of search :?
http://www.offroadexpress.co.nz/Forums/search.php?keywords=white+smoke&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
Weed out the dribble and try a few things.
Don't discount the glow plugs, pull them out or test each one in place. I have known of them to crap out fairly quick.
Could be injectors, fuel pump (not that likely), compressons, manifold heater (if fitted), could be head or gasket. Some simple methods of diagnosis should nail it down.
andrew007
Re: white smoke
Post by andrew007 »
check the glow plug timer,mite not be working or staying on longer enough. :shock:
dave gone jeepy
Re: white smoke
thanks guys all the info helps, one mechanic suggested rebuilding the fuel pump and working back from there that was going to be an expensive day
1hamish1
Re: white smoke
Post by 1hamish1 »
dave gone jeepy wrote:thanks guys all the info helps, one mechanic suggested rebuilding the fuel pump and working back from there that was going to be an expensive day
Think it through mate, never a good option to just start rebuilding everything and see if it helps. Do your homework first or small problems can cost heaps
mudslut
Re: white smoke
Post by mudslut »
Something to try is double or triple glowing it when cold before start up,it makes the world of difference on my L200 even with new glow plugs
Dan :D
tomsoffroad
Flopsie
Re: white smoke
Post by tomsoffroad »
The 4dr5's need heaps of glow in my experience. Wont start without it.
My old Cruiser diesel blows white smoke on cold mornings. I put it down to condensation in the exhaust.
White smoke is water somewhere.
dave gone jeepy
Re: white smoke
in the next week ill get an auto sparky to look at it, thanks guys the advice here is way better than some of the mechanics I've talked to
coop
Re: white smoke
Post by coop »
tomsoffroad wrote:White smoke is water somewhere.
Or unburnt fuel when cold.
Ever thought an injector/s could be leaking?
Pull off the exhaust manifold and start it, see if any excess smoke comes out what cylinder.
JK Wrangler 35s.
axel
Re: white smoke
Post by axel »
Is it auto or manual? Transmission fluid also burns white
DieselBoy
Re: white smoke
Post by DieselBoy »
axel wrote:Is it auto or manual? Transmission fluid also burn white
Awesome!!!!!
Care to explain how the transmission fluid could get burnt in the engine??
axel
Re: white smoke
Post by axel »
Awesome!!!!!
Sure thing:
If its an auto the rubber diaphragm in the vacuum modulator can fail which draws the transfluid back into the intake manifold. It about a $15 fix.
DieselBoy
Re: white smoke
Post by DieselBoy »
axel wrote:
Awesome!!!!!
Sure thing:
Learn something new every day eh :D :D :D :D
http://www.asashop.org/autoinc/sept2000/mech.htm
cornfarmer
Re: white smoke
Post by cornfarmer »
Yeah a leaking injector or one thats stuck open will cause white smoke. The injector will leak into the cylinder and on the exhaust stroke pump the diesel into the exhaust manifold. Coolant entering the cylinders will cause white smoke or steam (this may also bend conrods if it gets bad enough). I've seen some with a failed head gasket leak coolant into the cylinders over night. Like tomsoffroad said, condensation in the exhaust will do it too. Does it use any coolant? Check the simple things before spending big $ rebuilding pumps etc.
Nothings a problem if you don't give a f#ck.
