The long block (ex manifolds pumps etc) weighs 200kg
The cylinder head weighs 50kg so have to make sure its 100% ready to go on
Andrews 80 Series Cruiser tidy up
- Andrew1706
Re: Andrews 80 Series Cruiser tidy up
Andrew1706 wrote:The long block (ex manifolds pumps etc) weighs 200kg
farkme..
Following ya thread as you have a lot a detail..
- Andrew1706
Of course thats nothing in terms of diesel engines ...
It does give you a certain respect for your vehicle especially considering the amount of times my poor old girl has come to a suddent stop thanks to a tree or bank ... the engine still wants to keep moving even if the body isnt!
- Andrew1706
And the weight works against me
4 stitches
I have a trolley that my old man got from work a month ago that needs a few modifications and the engine will sit in there a lot better.
Always the case, think of a newer safer idea then casually forget about it then murphys law strikes and hurts your knee
Anyway heres a poser pic
I threw out the old headbolts and washers not know that the new set didnt come with washers!!!!
So in the meantime been doing some port matching since it's cheap and even if its only a small benefit, theres no harm in doing it
4 stitches
Ummmmmmm Ouch!!!
Did you break anything on the block??
- Andrew1706
^^ only broke the vaccum controlled throttle adjustment thingy for the A/C I think, biffed it.
New stand:
Head bolted down, just gotta get new tensioner and spring as this one is too loose for my liking
Then do turbo, clutch, injectors $$$$$$$$$$$$$$$$$$$$$
New stand:
