newbie with what is that dam button question?!
Hi guys,
Just picked myself up a 94 terrano 2.7 diesel manual truck a couple of days ago. Only done a short little road trip from buying it up in auckland back to home in Queenstown but pretty chuffed so far, had heaps more grunt than was expecting and seems to go pretty smoothly.
The whole way down though I was doing my nut in trying to work out what the button to the left of the steering wheel does. Its a pull out button that has a picture of a transmission on it (think thats what it is anyways). If it wasnt a diesel would have guessed it was the choke. 4hrs searching on the internet and i'm still no closer to finding out what it is.
Will some one please put me out my misery and tell me what the dam it is?!
Thanks heaps
Henry
Thanks heaps
Henry
Re: newbie with what is that dam button question?!
henrysj wrote:Hi guys,
Thanks heaps
Henry
If its the one im thinking of, its like a hand throttle, pull it out and you'll see.
If its the one im thinking of, its like a hand throttle, pull it out and you'll see.[/quote]
Thanks i'll give it a go. I think it only comes out a couple of cm's though
Try Turning it ,Revs should increase.
have you done it yet???
badnuz wrote:have you done it yet???
nope stuck at work, will have to go for a spin when i get home
yeah badnuz spot on, it does increase the revs - thanks
now does anyone ever use it for anything, cant really see the point of it on a diesel
- mud_slinger
its when you are lazy and in 4wd you can take ya foot off accelerator and use the idle up
needs more curry
0272593533
0272593533
itd be usefull if you had a tipper on your terrano
- niblik
- Sausage Shack
hand throttles are handy to up the rev's when doin winching or bimblin along uneven terrain.. also for warmin up ya rig..
i lurves mine..
i lurves mine..
also been use full when stuck so you can have wheels spinning slightly and get out and push haha
I have used mine for cruise control on the motorway, doesn't disengage when you hit the brake though
Hand throttle, used for warm up or charging flat battery or uneven ground much smother than the foot.
Our old man used it to set the speed on the farm truck then let us kids steer while he was on the trailer when feeding out.
- Winch master
If it doesnt work dont worry as mine didn't. they are sometimes disconnected. It is supposed to be a hand throttle. It is a pull and twist to lock type.
Ull want it in Qtwn in winter, go start it up in the morning,crank the idle up a bit aswell as the heater and demister.Go inside finish ya Coffee and toast, go back outside, revin its tits off but cosy warm and frost free windows.
it is a hand throttle use it while the engine is warming up so the engine runs smoother and when it is warm drop the revs back down to normal again usually only need to increase the revs by less than 100 rpm to get rid of the shudder
my 4wd is not a truck
Also real handy on steep hill starts when the hand-brake won't hold. Keep ya right foot on the brake and wind up the revs a little so it doesn't stall when you let the clutch in....
