Hi,
seems there have been a fair few Rover motors gone into Hilux's over the years - what adapters have people used to mate the V8 up to the G52 or W56 bellhousings?
And does anyone know wherewe might find one?
Glen
Rover V8 + Hilux gearbox
Re: Rover V8 + Hilux gearbox
hi glen brian howart made mine,hilux bell housing with the front cut off and a plate made up to match the rover motor, using rangie flywheel pressure and clutch plate with the spline cut out of the clutch plate and replaced with a hilux one, heaps of torque with the rangie flywheel
a another option for you
http://www.conversioncomp.co.nz
toysuzi:(SJ413) 3Y E surf engnie, 6" coil kit (RRO). toy diffs (4.88 R&P) & toy hilux box and t-case.
ifs toy power steering, 6" Bushwacker fender flares (RRO). ect
toysuzi wrote:a another option for you
Cheers, but at Total Conversion Kit $2310 I think not......
Cheers Karam - yours for sale
- mud_slinger
swampa wrote:rangie flywheel pressure and clutch plate with the spline cut out of the clutch plate and replaced with a hilux one, heaps of torque with the rangie flywheel
needs more curry
0272593533
0272593533
- Sadam_Husain
- Angry bird
we're part way through doing a conversion on Possum's boys hilux, I dont really know anything about lux or rover stuff but I'm learning shit as we go, I dont even know what series gearbox we've got but I know its not the bigger stronger type? We came accross a Graham Berry bellhousing, it wasnt setup for a lux box and had already been modified a few times before we got it, we got Brian to re-machine the face and redrill it for the lux box. He turned up a bush to go into the end of the crank for the input shaft, we used a rangie pressure plate, 4 cyclinder diesel cruiser clutch plate (same spline as the lux input shaft and right diameter for the rangie pressure plate), reused the lux clutch fork with a hiace release bearing, dont know what hiace coz I didnt sort out the bearing. We did a dummy run bolting the engine and gearbox up in the truck and it all seemed to fit and we put it all back in again with the clutch a couple of weeks ago and it all seems ok so far, no engine mounts or exhausts yet. Theres no room for the radiator so that will be rear mounted behind the cab and the standard exhaust manifolds are a little wider than the chassis rails but it looks like we will be able to sneak some pipes up to the flanges and I think we are going to have to shift the track bar on the front diff to the side a little bit coz the corner of the sump or something was going to hit it?
- Sadam_Husain
- Angry bird
optimistik_lux wrote:where did the bell housing come from was it just a one off thing?
my mate picked it up on the scrap run, I think all that Graham Berry stuff was around in the 1980's?
Good write up sadam, mine is in and running, got a spigot bush made up out of brass as well.
- Sadam_Husain
- Angry bird
NJV6 wrote:Good write up sadam, mine is in and running, got a spigot bush made up out of brass as well.
yeah I see its a pretty old thread, are there any more tricks or tips that we dont know about coz we havent finished our conversion yet?
