Im trying to help my friend out by getting his jeep running for him anyway here is the problem he was at the lights the other day when it just stopped it only turns over wont even fire so he got it towed home i have checked the fuel pump and it seems to be pumping and has good pressure in the fuel rail. I have tested the cam hall sensor in the distributor tested good. its getting no spark and was wondering if they run a crank sensor?I checked the coil with my meter and im getting the same readings with others i found at pick a part on the same type of jeep. Has anyone had this sort of fault or know of a common fault for this kind of jeep. oh and its a 1994 6cly 4.0l
cheers guys.
1994 4.0L JEEP NO START HELP!!
pajero1983
- Bush Crasher
Re: 1994 4.0L JEEP NO START HELP!!
v8 tj...luvs the gas......
pajero1983
- Bush Crasher
yeti wrote:http://www.cherokeeforum.com/attachments/f2/34100d1294886673t-97-xj-wont-start-when-wet-out-crankshaft_position_sensor_diagram.jpg
check that
Cheers mate i will have a look tommrow now i know were it is
say thats what it will be..... tell ya mate to save this site
http://jeep-xj.info/HowtoCPSchange.htm
will save him some coin ....
