If you order new, make sure you get the right type. Early versions (yours) have a 23 spline count on the shaft (outer joint), new ones are 24. So count your splines and specify them in the order. Regards, Hoodoo
Okay, are my splines 22 or 23? I have seen new ones on the Lada Hamburg website, and the splines are either 22 for the older models or 24 for the newer ones...?
