oldyella wrote:Hooked up to go to Magoo
Awesome - truck is looking mint
Well Done
oldyella wrote:Then after a few tweaks, putting my pressure tested radiator in and some water pipe plumbing, I rolled it down the drive, then drove back up![]()
http://www.facebook.com/photo.php?v=2585377523731&set=vb.1533324011&type=2&theater
MNC wrote:NiceLooks like a tight squeeze to get into that garage now
oldyella wrote:Planning on taking it to Sims brakes to get the lines run. Tried to do it myself but decided it was to hory
oldyella wrote:Thanks Nibs got the fuel caps sorted. Landrover made three different types in total![]()
What I haven't got sorted is my fuel pump system. Its driving me nuts![]()
This stupid bosch check valve. Does anyone know where I can buy a suitable banjo fitting. Its not a normal banjo fitting because it doesn't suit a banjo bolt but a nut instead.
The other idea I had was to remove it and just run an inline check valve. But I can't find anyone who sells an inline check valve.
Will it be no good if I just run no check valve?
The other thing was braded fuel line. I was going to use alloy anodized "push lok" connectors. Are these good to use with the stainless braded fuel line?
Any advice would be great or places which sell this kind
klompy wrote:Can you use a normal banjo fitting with a dome nut.
oldyella wrote:
Pedro - I was under the impression the check valve is also needed to retain pressure in fuel rail for starting?
Pete
